Community Member
PIX 7.0 VPN : Inside LAN is unreachable
Hi ,
i have established vpn connection with cisco vpn client 4.7.0 and the connection work, but all server and workstation inside lan is unreachable.
My config is attached.
Can you help me?
Gold
Re: PIX 7.0 VPN : Inside LAN is unreachable
may give this command a go, "isakmp nat-traversal".
Community Member
jackko, thanks but not work.
I make connection and i received autentication e ip address from pix, but when i try to connect inside local hosts, these are unrecheable.
This is my network:
INSIDE LAN(192.168.149.0) ->(inside IF 192.168.149.123) PIX (outside IF 10.10.10.9) -> (eth0 10.10.10.10)adsl_router -> INTERNET
The adsl_router is a cisco 800 and make nat from eth0 and adsl interface.
My pix config is attach.
Thanks to all
Gold
just wondering if pix outside interface has a public ip, or the adsl router is performing a static nat.
233
