PIX 7.01 downgrade Problem
I can downgrade PIX OS 7.01 to 6.35 (UR License) but failover license when downgrade finished. Licensed changed to R License. How can I do? I can't to used failover feature
1 REPLY
Silver
Re: PIX 7.01 downgrade Problem
If the PIX had previously been upgraded from a PIX Version 6.3 version, the 4-tuple activation key is stored in Flash and does not need to be re-entered. Even if the PIX Version 7.0 code license had been subsequently updated using a 5-tuple activation key, the 4-tuple key is still saved. The downgrade command verifies and uses the 4-tuple key, if it exists. Otherwise, the activation key needs to be input in the CLI for the command to succeed.
89
