PIX 7.x INFO MESSAGE
gcocchi
I receive this messagge from my pix 525 7.1.2:
"INFO: Outside address overlap with static NAT configuration"
What is means?
Fernando_Meza
Level 7
Level 7
It sounds like you have a static instruction and you are using a Public address which is probably already allocated to one of your interfaces. Please type a
show run | inc static and also show run | inc address and post it to have a quick look
I cleared all static configuration and added e simple example to test it, but the error message still here.
The strange thing is that only when i'm inserting a new network object in an object group the INFO message appear.
Why?
Using the command you gave to me i cannot see overlapping addresses ...
Inside 192.168.97.0/24
Outside 192.168.251.0/24
Dmz 192.168.249.0/24
I have a route on inside to 192.168.0.0/16 is this the problem?
I found that removing nat exemption access-list, the overlapping message go away.
I think i made some mistake on con figuring exemption and static nat, but i cannot find the solution.
If you like post the config and I will have a look
