10-24-2002 12:46 PM - edited 02-20-2020 10:19 PM
We have a PIX running 4.4(5). When accessing and internal FTp server form the outside, random connections time out. We ave tried passive mode with no improvement.
Any other ideas?
Brian
Solved! Go to Solution.
10-24-2002 01:01 PM
Not sure if this applies to you: bug CSCds48493
First thought is to upgrade the OS to at least 5.x if not 6.x.
Hope it helps.
Steve
10-24-2002 01:01 PM
Hope it helps.
Steve
10-24-2002 01:20 PM
Steve,
Thanks for the tip. That looks like it may be the issue. I was looking for the incentive to get the PIX software updated.
Brian
10-24-2002 08:29 PM
If you want to stay on the 4.4 train specifically (some customers like to), then you can upgrade to 4.4(8) for the fix. Otherwise any v5 or v6 code should be fine.
