PIX and Intel Lan Rover VPN /Tunneling Interoperability
lbacchi
Hi, does is possible to create a VPN Tunneling bettwen a PIX and a Intel Lan Rover ?
murabi
Level 4
Level 4
I know Cisco’s PIX’s and routers are open standard IPSec devices, and I believe Intel’s Lan Rover should be too. If you already have the Intel’s in place, I’d check with them to be sure. If you haven’t purchased it yet, I’d suggest getting a small Cisco router. I’ve learned it’s always easier to deal with a one vendor solution from a support standpoint. Just my two cents.
