Community Member
pix and ipsec passthrough
hi all
i'm looking for a way to configure ipsec passthrough on pix (performing pat and ipsec with a device on inside from a device on outside).this is possible on a ios plateform with these cmdes.
int fast 0
ip add
ip nat inside
int ser 0
ip add
ip nat outside
ip nat inside srce static udp insidadd 500 outsadd 500
ip nat inside srce static esp insidadd outsadd
thanks for your help
Re: pix and ipsec passthrough
I believe this is what you are looking for:
http://www.cisco.com/univercd/cc/td/doc/product/iaabu/pix/pix_sw/v_63/config/fixup.htm#1094669
This is a new feature in the 6.3 code so you will need to upgrade your PIX code if you are not already on a 6.3 release. Hope this helps.
Scott
Hello
Try using this command on ur pix
sysopt connection permit-ipsec
sysopt connection permit-pptp
Ephraim
103
