PIX and VPN with Linksys... weird problem!
People:
I am having the weirdest of the problems... I have a PIX515E with several Linksys BEFX41 routers with VPNs..... suddenly... the VPNs cannot be established... I have Linksys routers distributed in diferent places... and all of them are unable to connect. ... I even tried connecting with a Linksys right next to the ouside interface.. with an contiguous IP to the one assigned to the PIX's outside interface.... (you'll see that below.. the .34 and .44 addresses)..No luck either
so far... I have discarded my ISP... the linksys routers (if were only one I would suspect that... but with 3 or 4 failing...)... and I don't remember making any change to the firewall in the last weeks in fact I compared the last good known configuration and it's fine....
whenever I hit the connect buttom in the Linksys router I got the following response in the PIX
(and then the linksys routers hang and I have to reboot them!)
-----------------------------------------------------crypto_isakmp_process_block: src X.X.X.44, dest X.X.X.34
VPN Peer: ISAKMP: Peer ip:X.X.X.44 Ref cnt incremented to:1 Total VPN
Peers:1
OAK_MM exchange
ISAKMP (0): processing SA payload. message ID = 0
ISAKMP (0): Checking ISAKMP transform 1 against priority 10 policy
ISAKMP: encryption DES-CBC
ISAKMP: hash SHA
ISAKMP: auth pre-share
ISAKMP: default group 1
ISAKMP: life type in seconds
ISAKMP: life duration (VPI) of 0x0 0x1 0x51 0x80
ISAKMP (0): atts are not acceptable. Next payload is 3
ISAKMP (0): Checking ISAKMP transform 2 against priority 10 policy
ISAKMP: hash MD5
ISAKMP (0): atts are acceptable. Next payload is 3
ISAKMP (0): SA is doing pre-shared key authentication using id type ID_FQDN
return status is IKMP_NO_ERROR
OAK_MM exchange
ISAKMP (0): processing KE payload. message ID = 0
ISAKMP (0): processing NONCE payload. message ID = 0
OAK_MM exchange
ISAKMP (0): processing ID payload. message ID = 0
ISAKMP (0): processing HASH payload. message ID = 0
ISAKMP (0): SA has been authenticated
ISAKMP (0): ID payload
next-payload : 8
type : 2
protocol : 17
port : 500
length : 10
ISAKMP (0): Total payload length: 14
ISAKMP (0): sending INITIAL_CONTACT notify
ISAKMP (0): sending NOTIFY message 24578 protocol 1
-----------------------------------------------------as you can see... looks like the connection starts to be established.. but it stops right after sending that NOTIFY message.....
any idea?? or similar problem in the past??? I tried rebooting the firewall... rewriting the configuration..... etcetera... and no luck...
I attach my PIX configuration below.... thanks a lot for any help with this!
-----------------------------------------------------PIX Version 6.1(2)
nameif ethernet0 outside security0
nameif ethernet1 inside security100
nameif ethernet2 dmz security10
hostname PIX01
fixup protocol ftp 21
fixup protocol http 80
fixup protocol h323 1720
fixup protocol rsh 514
fixup protocol smtp 25
fixup protocol sqlnet 1521
no fixup protocol rtsp 554
no fixup protocol sip 5060
no fixup protocol skinny 2000
names
access-list 100 permit tcp any host X.X.X.37 eq smtp
access-list 100 permit tcp any host X.X.X.37 eq pop3
access-list 100 permit tcp any host X.X.X.37 eq domain
access-list 100 permit udp any host X.X.X.37 eq domain
access-list 100 permit tcp any host X.X.X.35 eq www
access-list 100 permit tcp any host X.X.X.35 eq 443
access-list 100 permit tcp any host X.X.X.36 eq www
access-list 100 permit tcp any host X.X.X.36 eq 443
access-list 100 permit tcp any host X.X.X.36 eq domain
access-list 100 permit udp any host X.X.X.36 eq domain
access-list 100 permit tcp any host X.X.X.38 eq www
access-list 100 permit tcp any host X.X.X.38 eq 443
access-list 100 permit tcp any host X.X.X.37 eq www
access-list 100 deny icmp any any
access-list 100 permit tcp any host X.X.X.42 eq www
access-list 100 permit tcp any host X.X.X.42 eq 443
access-list 100 permit tcp any host X.X.X.43 eq www
access-list 100 permit tcp any host X.X.X.43 eq 443
access-list 100 permit tcp any host X.X.X.39 eq www
access-list 100 permit tcp any host X.X.X.39 eq 443
access-list 100 permit tcp any host X.X.X.41 eq www
access-list 100 permit tcp any host X.X.X.41 eq 443
access-list 100 permit tcp any host X.X.X.46 eq www
access-list 100 permit tcp any host X.X.X.46 eq 443
access-list 101 permit tcp any any
access-list 101 permit udp any any
access-list 101 permit ip any any
access-list nonat permit ip 192.168.1.0 255.255.255.0 192.168.3.0 255.255.255.0
access-list nonat permit ip 192.168.1.0 255.255.255.0 192.168.4.0 255.255.255.0
access-list nonat permit ip 192.168.1.0 255.255.255.0 192.168.5.0 255.255.255.0
access-list nonat permit ip 192.168.1.0 255.255.255.0 192.168.6.0 255.255.255.0
access-list nonat2 permit ip 192.168.2.0 255.255.255.0 192.168.3.0 255.255.255.0
access-list nonat2 permit ip 192.168.2.0 255.255.255.0 192.168.4.0 255.255.255.0
access-list nonat2 permit ip 192.168.2.0 255.255.255.0 192.168.5.0 255.255.255.0
access-list nonat2 permit ip 192.168.2.0 255.255.255.0 192.168.7.0 255.255.255.0
access-list nonat2 permit ip 192.168.2.0 255.255.255.0 192.168.6.0 255.255.255.0
pager lines 24
interface ethernet0 auto
interface ethernet1 auto
interface ethernet2 auto
mtu outside 1500
mtu inside 1500
mtu dmz 1500
ip address outside X.X.X.34 255.255.255.224
ip address inside 192.168.1.1 255.255.255.0
ip address dmz 192.168.2.1 255.255.255.0
ip audit name attack1 attack action alarm drop reset
ip audit interface outside attack1
ip audit info action alarm
ip audit attack action alarm drop reset
pdm history enable
arp timeout 14400
global (outside) 1 X.X.X.50-X.X.X.61 netmask 255.255.255.224
global (outside) 1 X.X.X.62 netmask 255.255.255.224
nat (inside) 0 access-list nonat
nat (inside) 1 192.168.1.0 255.255.255.0 0 0
nat (dmz) 0 access-list nonat2
alias (inside) 192.168.1.2 X.X.X.38 255.255.255.255
alias (inside) X.X.X.36 192.168.2.11 255.255.255.255
alias (inside) X.X.X.35 192.168.2.10 255.255.255.255
alias (inside) X.X.X.37 192.168.2.12 255.255.255.255
alias (inside) X.X.X.40 192.168.2.14 255.255.255.255
alias (inside) X.X.X.42 192.168.2.16 255.255.255.255
alias (inside) X.X.X.43 192.168.2.17 255.255.255.255
alias (inside) X.X.X.39 192.168.2.19 255.255.255.255
alias (inside) X.X.X.45 192.168.2.18 255.255.255.255
alias (inside) X.X.X.41 192.168.2.15 255.255.255.255
alias (inside) 192.168.1.14 X.X.X.46 255.255.255.255
alias (dmz) 192.168.2.16 X.X.X.42 255.255.255.255
alias (dmz) 192.168.2.17 X.X.X.43 255.255.255.255
alias (dmz) 192.168.2.19 X.X.X.39 255.255.255.255
alias (dmz) 192.168.2.18 X.X.X.45 255.255.255.255
alias (dmz) 192.168.2.15 X.X.X.41 255.255.255.255
static (dmz,outside) X.X.X.36 192.168.2.11 netmask 255.255.255.255 0
static (dmz,outside) X.X.X.35 192.168.2.10 netmask 255.255.255.255 0
static (inside,outside) X.X.X.38 192.168.1.2 netmask 255.255.255.255
static (dmz,outside) X.X.X.37 192.168.2.12 netmask 255.255.255.255 0
static (inside,dmz) 192.168.1.0 192.168.1.0 netmask 255.255.255.0 0 0
static (dmz,outside) X.X.X.40 192.168.2.14 netmask 255.255.255.255 0
static (dmz,outside) X.X.X.42 192.168.2.16 netmask 255.255.255.255 0
static (dmz,outside) X.X.X.43 192.168.2.17 netmask 255.255.255.255 0
static (dmz,outside) X.X.X.39 192.168.2.19 netmask 255.255.255.255 0
static (dmz,outside) X.X.X.45 192.168.2.18 netmask 255.255.255.255 0
static (dmz,outside) X.X.X.41 192.168.2.15 netmask 255.255.255.255 0
static (inside,outside) X.X.X.46 192.168.1.14 netmask 255.255.255.255
access-group 100 in interface outside
access-group 101 in interface dmz
route outside 0.0.0.0 0.0.0.0 X.X.X.33 1
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 rpc 0:10:00 h323 0:05:00
si
p 0:30:00 sip_media 0:02:00
timeout uauth 0:05:00 absolute
aaa-server TACACS+ protocol tacacs+
aaa-server RADIUS protocol radius
no snmp-server location
no snmp-server contact
snmp-server community public
no snmp-server enable traps
floodguard enable
sysopt connection permit-ipsec
no sysopt route dnat
crypto ipsec transform-set router-set esp-des esp-md5-hmac
crypto dynamic-map cisco 1 set transform-set router-set
crypto map dyn-map 10 ipsec-isakmp dynamic cisco
crypto map dyn-map interface outside
isakmp enable outside
isakmp key ******** address 0.0.0.0 netmask 0.0.0.0
isakmp policy 10 authentication pre-share
isakmp policy 10 encryption des
isakmp policy 10 hash md5
isakmp policy 10 group 1
isakmp policy 10 lifetime 86400
1 REPLY
Gold
Re: PIX and VPN with Linksys... weird problem!
Hi -
Seems like you are having similar problems as Rod Cagila (on the VPN Security forum), Please read the following doc:
http://www.cisco.com/univercd/cc/td/doc/product/iaabu/pix/pix_60/ipsec/
And also, Rod has a solution to this you can contact him at:
rod.caglia@electricmotorshop.com
Let me know how you get on... Jay
90
