PIX ASDM questions
Does anyone know if ASDM has different levels of security know. For example, can make some users with read-only access and some with access to everything. On PDM it is an all or nothing thing. Specifically, I want users to be able to reset VPN tunnels and view information but NOT change the configuration of any devices. Is this possible?
Silver
Re: PIX ASDM questions
ASDM is an application-based configuration tool designed to help you set up, configure, and monitor your PIX firewall with a GUI. PIX firewalls are placed at two different sites. A tunnel is formed using IPsec. IPsec is a combination of open standards that provide data confidentiality, data integrity, and data origin authentication between IPsec peers For more information refer to the following url:
http://www.cisco.com/en/US/products/hw/vpndevc/ps2030/products_tech_note09186a00804708d8.shtml#t8
I don't mean to sound unappreciate but that repsonse didn't answer anything. I know what a tunnel is. From another post I also now understand that ASDM CAN reset vpn tunnels where as PDM couldn't. I just want to know there are also security "levels" now part of ASDM. In PDM, it was all or nothing as far as security goes.
97
