PIX DMZ relay smtp server problem
Have a 515E PIX with a "Internet" ip range for both the outside and DMZ interface.
I'm having a problem when I specify and access list to allow the mail relay to forward mail to the internal mail server.
This is my config
fixup protocol smtp 25
access-list Sydney2match permit ip 192.168.107.0 255.255.255.0 192.168.33.0 255.255.255.0
access-list Sydney2match permit ip 192.168.107.0 255.255.255.0 192.168.100.0 255.255.255.0
access-list Sydney2match permit ip 192.168.184.0 255.255.248.0 192.168.33.0 255.255.255.0
access-list Sydney2match permit ip 192.168.184.0 255.255.248.0 192.168.100.0 255.255.255.0
access-list SMTP permit tcp any host x.y.163.178 eq smtp
access-list NONAT permit ip 192.168.184.0 255.255.248.0 192.168.100.0 255.255.255.0
access-list NONAT permit ip 192.168.184.0 255.255.248.0 192.168.33.0 255.255.255.0
access-list NONAT permit ip 192.168.107.0 255.255.255.0 192.168.100.0 255.255.255.0
access-list NONAT permit ip 192.168.107.0 255.255.255.0 192.168.33.0 255.255.255.0
access-list dmz_outbound_nat0_acl permit ip x.y.163.176 255.255.255.240 any
access-list SMTPINSIDE permit tcp host x.y.163.178 host 192.168.185.50 eq smtp
access-list SMTPINSIDE permit tcp host x.y.163.178 any eq smtp
ip address outside x.y.165.22 255.255.255.248
ip address inside 192.168.185.1 255.255.255.0
ip address dmz x.y.163.177 255.255.255.240
global (outside) 1 interface
nat (inside) 0 access-list NONAT
nat (inside) 1 192.168.185.0 255.255.255.0 0 0
nat (dmz) 0 access-list dmz_outbound_nat0_acl
static (inside,dmz) 192.168.185.0 192.168.185.0 netmask 255.255.255.0 0 0
access-group SMTP in interface outside
access-group SMTPINSIDE in interface dmz
route outside 0.0.0.0 0.0.0.0 x.y.165.21 1
route inside 192.168.107.0 255.255.255.0 192.168.185.253 1
crypto map SYDIMC 100 match address Sydney2match
PS. If I remove "access-group SMTPINSIDE " I can telnet to the relay server, but not the inside mail server.
  • Other Security Subjects
1 REPLY
Re: PIX DMZ relay smtp server problem
I'm a little confused as to what you're trying to do here. You mention you can telnet to the relay server, from where? To get to the relay server from the outside you need:
static (dmz,outside) x.y.163.178 x.y.163.178 netmask 255.255.255.255
along with your SMTP access-list. From there, if the DMZ server is supposed to send mail to the inside server, then your SMTPINSIDE and static that you have shown should be enough. What do you get if, from the DMZ server, type:
> telnet 192.168.185.50 25
If you get connected then the static/ACL is working as it should. If this is a Exchange server you may need to turn of the SMTP fixup with:
> no fixup protocol smtp 25
Other than that, whenever you have connectivity problems, always enable syslogging with:
logging on
logging cons debug
and try a connection, the PIX will then tell you exactly what it's allowing and/or denying.
183
