07-10-2007 04:21 AM - edited 02-21-2020 01:36 AM
Hi all,
Id like to consult second problem
with our failover with PIXs 525 and PIXOS 7.0.4. Both are connected with serial cable and dedicated ethernet cable.
Problem is:
When I disconnect one interface on
Primary-Active PIX than other one takes
role. But when I connect interface back I see on primary one (CLI command show failover) that it is secondary and one which was secondary is primary. But active is now the same as before but is signed as secondary. Cable is placed correctly..primary side on primary and secondary side on failover (secondary).
Any idea?
BR
jl
07-10-2007 04:25 AM
Hi Jl
This is normal behaviour for the pix with failover. The secondary will be active if it sees the pix primary goes down. But when the prinary comes back up it will not take over as the primary, it will assume the role of secondary.
It is not a problem.
Jon
07-10-2007 06:08 AM
Hi Jon,
thanks for info....but why PIX before Primary
and now Secondary is Secondary-Active?
Why they don?t change only state Active ..Standby. But they change Secondary and Primary
roles. I thought that serial cable determine roles and this don?t change.
BR
jl
07-10-2007 06:17 AM
Hi Jl
The cable does determine which is primary and which is secondary and as you point out if you connect the cable the wrong way round failover will not work.
But the firewall coming back up does not preempt the active firewall. Thinking of primary and secondary can be a bit misleading in this sense. Think of it as active and standby. Either firewall can be active or standby.
Jon
07-10-2007 07:55 PM
You will need to issue (from configuration mode)
the failover active command on the primary (standby) pix.
Simply telnet to the failover inside IP address and issue the command.
You will then loose your connection.
07-10-2007 11:59 PM
Hi all,
thanks for an advice. Now Im knowledgeabled.
I entered the command failover active and everything is like before. Fine.
jl
07-11-2007 12:21 AM
Glad to hear.
Likewise you could have just pulled a cable from the Secondary active to have failover fail back to the primary. :)
There is also an active light on the front to help determine which firewall is currently active.
Cheers
