PIX Failover
gavin.mckee
can anyone offer a suggestion to this problem. The secondary device is showing failed. I assume that this is because the hello packets are not being recieved on the failover interface. I think it may be a static(inside,outside) command. Is there anyway of debug this to find out whats stopping the hello command.
dub1# sh failover
Failover On
Cable status: Normal
Reconnect timeout 0:00:00
Poll frequency 15 seconds
This host: Primary - Active
Active time: 22538970 (sec)
Interface dmz (192.168.67.1): Normal (Waiting)
Interface outside (217.173.100.33): Normal (Waiting)
Interface inside (172.22.66.140): Normal (Waiting)
Other host: Secondary - Standby (Failed)
Active time: 497700 (sec)
Interface dmz (192.168.67.2): Normal
Interface outside (217.x.100.x): Normal
Interface inside (172.22.66.141): Normal
Stateful Failover Logical Update Statistics
Link : Unconfigured.
18 Replies 18
andrew.burns
Level 7
Level 7
You don't say whether this is a new install or an existing one which has since failed...
Anyway - this doc gives a lot of detail and help with troubleshooting failovers:
http://www.cisco.com/en/US/products/hw/vpndevc/ps2030/products_tech_note09186a0080094ea7.shtml
it's unlikely to be a problem with a static statement because statics are not used as part of the failover process. It could be a problem switch or ports not in a common vlan or something like that though.
A diagram and the pix configs might give us more clues...
Andrew.
Hi Andrew,
Thanks for your time on this. I have just started working on this network and the pix setup has been in for a few years. Duing my checks of the network I have noticed this failover problem.
The two pix are connected via the failover cable.
The failover config is:
failover
failover timeout 0:00:00
failover poll 15
failover ip address outside XXX.173.100.34
failover ip address inside 172.22.66.141
failover ip address dmz 192.168.67.2
The outside and dmz interface is on VLAN217 (this is hooked up to a 3550 which is directly into the ISP cloud.)
The Inside interfaces are on VLAN66 which is hooked up to a 6509
Any help is great
Have you tried a reset? i.e. "failover reset"
Andrew.
how come your failover IP address is the same IP of your inside interface address?
i did not write this configuration. i have just started working for a company who have this set up in place. do you think i should chage the failover ip address?
I'll try "failover reset" does this have any side affects can I run it on a production system?
Change your failover IP address before reset.
When you do "failover reset" does the interface reset? If yes you can't do that in a production system.
so whats the constrainsts of the failover ip address. there has to be one for each interface i take it, therefore to change the failover ip it must be in the same subnet.
Forgive my ignorance some of this pix stuff is new to me.
Gavin
Here's what the manual says:
failover reset
Force both units back to an unfailed state. Use this command once the fault has
been corrected. The failover reset command can be entered from either unit, but
it is best to always enter commands at the active unit. Entering the failover reset
command at the active unit will ?unfail? the standby unit.
So, the only effect should be to unfail the secondary - if the fault is still there then it'll just fail again.
Whether to run it on a production system depends on many factor, such as what change control system you run, what SLA's are in force, your relationship with the users, etc, etc. I personally think it's safe - but it's not my network ;-)
I noticed that you're not running stateful failover, so if you do have a failover then it'll take at least a minute to recover.
Up to you!
Andrew.
Not sure what the other poster means about ip addresses - they look fine to me.
Andrew.
Hi andrew. What do you think if he changes The failover IP address.
I think Failover IP Address Failover do not need to be in the same subnet of your network. you can use a crossover between them.
Thanks Andrew, thats some excellent advice. There is a change control system, the company provides electronic trading services on the worlds stock exchanges!! so i'll probably have to wait until the trading day is over :).
The pix has three interfaces fa0/0,1,2 i.e. Outside,Inside and DMZ. From what I can see I would need another 802.3 interface connected to a switch in order to do stateful failover. Maybe this would be a good option! Am I right about the fact that I need another interface?
Sorry about all these questions but i've only recently became CCNA!! Respect to all CCIE :)
Could you also tell me how the actual failover interface is addressed in a pix. I thought you should be able to look at it like any interface e.g. show interface s0/0
Version is 6.1
Gavin
ok. you have only 3 interfaces.
