Pix firewall for both site to site and site to client
I have cisco pix firewall which i have configured for both site to site and site to clinet. Clients are able to connect using vpn client but when i have a site to site with customer's firewall(Symantec) and when i try to ping his internal ip address 170.102.16.14 i am getting this error message from the firewall
IPSEC(sa_initiate): ACL = deny; no sa created.
Below is my ipsec configuration for both site to site and site to client. Can some on help me in rectifying the problem. instance 10 is for site to client and instance 20 in crypto is for the site to site.
nat (inside) 0 access-list 108
access-list 108 permit ip 192.168.1.0 255.255.255.0 192.168.5.0 255.255.255.0
access-list 108 permit ip 192.168.2.0 255.255.255.0 host 170.102.16.41
access-list 110 permit ip 192.168.2.0 255.255.255.0 host 170.102.16.41
sysopt security fragguard
sysopt connection permit-ipsec
no sysopt route dnat
crypto ipsec transform-set myset esp-des esp-md5-hmac
crypto dynamic-map dynmap 10 set transform-set myset
crypto map mymap 10 ipsec-isakmp dynamic dynmap
crypto map mymap 20 ipsec-isakmp
crypto map mymap 20 match address 110
crypto map mymap 20 set peer x.x.x.x1
crypto map mymap 20 set transform-set myset
crypto map mymap client authentication authinbound
crypto map mymap interface outside
isakmp enable outside
isakmp identity address
isakmp key ******** address x.x.x.x1 netmask 255.255.255.255 no-xauth no-conf
ig-mode
isakmp policy 10 authentication pre-share
isakmp policy 10 encryption des
isakmp policy 10 hash md5
isakmp policy 10 group 2
isakmp policy 10 lifetime 86400
isakmp policy 20 authentication pre-share
isakmp policy 20 encryption des
isakmp policy 20 hash md5
isakmp policy 20 group 1
isakmp policy 20 lifetime 86400
vpngroup vpn3000 address-pool ippool
vpngroup vpn3000 dns-server 192.168.1.64
vpngroup vpn3000 wins-server 192.168.1.24
vpngroup vpn3000 default-domain test.dom
vpngroup vpn3000 split-tunnel 108
vpngroup vpn3000 idle-time 1800
vpngroup vpn3000 password ********
Thanks in Advance
1 REPLY
Bronze
Re: Pix firewall for both site to site and site to client
That message usually has something to do with the ACL not allowing that function. Looking at the ACL I am assuming that the host is the actual firewall on the otherside. If not then that could be the problem.
80
