Silver
PIX Interface in Normal(Waiting) state, and testing continuously
PIX 535, OS 6.3.1
Following a failover we are observing that some of the interfaces on the primary and secondary PIX are in Normal (Waiting) status. In the log, we see that those interfaces are continuously undergoing the testing process.
I know the interface will go into "testing" mode if it donot receive hellos from the other unit within a specified time. The interface status will be "waiting" if the interface receives one hello and is waiting for the second hello.
However what concerns me is that the interfaces are continuously in testing mode, and showing waiting status. Any ideas what could be the problem? Is there some network connectivity issues preventing the hellos from reaching the other units, or has the PIX interface gone bad.
Thanks for any help!!
pixfirewall# sh fail
Failover On
Cable status: Normal
Reconnect timeout 0:00:00
Poll frequency 15 seconds
This host: Secondary - Active
Active time: 563565 (sec)
Interface outside (x.x.x.x): Normal
Interface inside (x.x.x.x): Normal
Interface State (x.x.x.x): Normal (Waiting)
Interface XO (x.x.x.x): Normal (Waiting)
Interface DMZ_Web (x.x.x.x): Normal (Waiting)
Interface VPN (x.x.x.x): Normal
Other host: Primary - Standby
Active time: 14400 (sec)
Interface State (0.0.0.0): Normal (Waiting)
Interface XO (0.0.0.0): Normal (Waiting)
2003-06-26 07:12:58 Kernel.Alert 192.168.31.3 Jun 26 2003 07:12:58: %PIX-1-104004: (Primary) Switching to OK.
2003-06-26 07:12:58 Kernel.Alert 192.168.31.3 Jun 26 2003 07:12:58: %PIX-1-105003: (Primary) Monitoring on interface 5 waiting
2003-06-26 07:12:58 Kernel.Alert 192.168.31.3 Jun 26 2003 07:12:58: %PIX-1-105003: (Primary) Monitoring on interface 1 waiting
2003-06-26 07:12:58 Kernel.Alert 192.168.31.3 Jun 26 2003 07:12:58: %PIX-1-105003: (Primary) Monitoring on interface 0 waiting
2003-06-26 07:12:59 Kernel.Alert 192.168.31.2 Jun 26 2003 07:12:59: %PIX-1-105008: (Secondary) Testing Interface 4
2003-06-26 07:13:03 Kernel.Alert 192.168.31.2 Jun 26 2003 07:13:03: %PIX-1-105009: (Secondary) Testing on interface 4 Passed
2003-06-26 07:13:13 Kernel.Alert 192.168.31.3 Jun 26 2003 07:13:13: %PIX-1-104004: (Primary) Switching to OK.
2003-06-26 07:13:18 Kernel.Alert 192.168.31.2 Jun 26 2003 07:13:18: %PIX-1-105008: (Secondary) Testing Interface 4
2003-06-26 07:13:20 Kernel.Alert 192.168.31.2 Jun 26 2003 07:13:20: %PIX-1-105009: (Secondary) Testing on interface 4 Passed
2003-06-26 07:13:28 Kernel.Alert 192.168.31.3 Jun 26 2003 07:13:28: %PIX-1-105004: (Primary) Monitoring on interface 5 normal
2003-06-26 07:13:28 Kernel.Alert 192.168.31.3 Jun 26 2003 07:13:28: %PIX-1-105004: (Primary) Monitoring on interface 1 normal
2003-06-26 07:13:28 Kernel.Alert 192.168.31.3 Jun 26 2003 07:13:28: %PIX-1-105004: (Primary) Monitoring on interface 0 normal
2003-06-26 07:13:35 Kernel.Alert 192.168.31.2 Jun 26 2003 07:13:35: %PIX-1-105008: (Secondary) Testing Interface 4
2003-06-26 07:13:39 Kernel.Alert 192.168.31.2 Jun 26 2003 07:13:39: %PIX-1-105009: (Secondary) Testing on interface 4 Passed
Bronze
Re: PIX Interface in Normal(Waiting) state, and testing continuo
Have you plugged any cables on those interface? Lleaving it empty might also be a reason for this behaviour.
Assuming that your unconnected interfaces are shut down, I would lean toward a speed mismatch between the hub/switch and the firewall ints. If possible, avoid "auto" on both the hub/switch and the firewall and use fixed values instead.
You also might try simply reseating the cables in question.
403
