03-10-2004 08:45 PM - edited 02-20-2020 11:17 PM
I have a lab PIX with 6.3(3) on it and I tried to setup a logical interface with the following:
"interface ethernet2 10 logical"
This fails to create a logical interface, do I have to create a vlan somehow first?
PIX is 515 (Not the E type) and has a restricted version software release with only DES enabled if that matters?
A sample configuration of using VLANs on PIX would be great if anyone has one.
03-11-2004 04:37 AM
what did the pix say after you entered that command? what does a show interface show?
03-11-2004 05:09 AM
The PIX 515R can support 3 logical interfaces.
Check here for config information:
http://www.cisco.com/univercd/cc/td/doc/product/iaabu/pix/pix_sw/v_63/config/bafwcfg.htm#1113411
hopefully that helps...
03-25-2004 02:28 PM
This helped a lot, Thanks!
FYI, I spent another day finding another problem, here is the scoop if your interested...
When you setup the vlan with the "physical" entry the firewall uses a different native vlan than expected. Just by luck I found that if for instance you enter.
interface ethernet2 vlan2 physical
the firewall uses a native vlan 1
if you use interface ethernet2 vlan1 physical
the firewall uses native vlan 2
This continues to flip flop if you use
vlan 3 - 4
vlan 5 - 6
etc..
I had to use opposite native vlan on switch side to get traffic to pass on native vlan. Did not find a bug, but this is not the way it should work!
Again, Thanks for the help!
06-22-2004 01:32 AM
I am trying to put VLAN 1 in a trunk betweend pix and catalyst 65000, but I have issues,. Have you done it?, and How?.
Thank you for help
