06-07-2002 02:35 AM - edited 02-20-2020 10:05 PM
I have recently had a PIX stop forwarding traffic because of the 'reliable TCP syslog' feature, the syslog server had gone down.
To stop it happening again I changed the PIX to use logging via UDP instead, however the same thing happened again a couple of days ago despite being set to UDP!
Does the change from logging via TCP to logging via UDP happen instantly or does the PIX need a reload before this change takes effect?
Martin
06-07-2002 10:35 AM
Martin:
I'd had a similar problem [and have heard the same from other PIX admins] and was forced to switch back to UDP very quickly--I didn't need to reload the PIX to make the change active. Changing logging to UDP was immediate and the PIX started passing traffic again.
Ross
06-10-2002 12:58 AM
Hi Ross,
Thanks for your response. The weird thing is that I had managed to change logging to UDP with no problems and the syslog messages were working okay - however a few days later the syslog server went off-line and PIX fell-over again!
It may have just been a coincidence - I guess I should test the current setup out of hours to see if it happens again.
Martin
P.S. It turns out that the PIX stops passing traffic by design; if using TCP logging and the Syslog server is not available then 'don't pass what can't be logged'.
