Community Member
PIX PAT using ports below 1024
Outbound PAT is randomly choosing ports under 1024 which conflicts with perimeter router acl's. Is there a way to force the pix to use only ports above 1024?
PIX 525 with version 6.2.2
1 REPLY
Re: PIX PAT using ports below 1024
The PIX will choose from a range of ports dependent on the original source port. For example:
- If the source port is TCP/UDP 1-511, then the PIX will PAT the SRC address to one in that range.
- If the source port is TCP/UDP 512-1023, then the PIX will PAT the SRC address to one in that range.
- If the source port is TCP/UDP 1024-65535, then the PIX will PAT the SRC address to one in that range.
So you're original ports are in the range under 1024, therefore the PIX chooses a poart in that range. This can't changed however, it's just how it works.
133
