pix port forwarding
borknager
I have been having a little trouble getting these few commands to take.
I need to have to inside addresses mapped to allow to sessions of pcanywhere to go through. One to the server, and one for a pc that is used by an outside company
Here is what I was trying to get to work
static (inside,outside) tcp 5633 xxx.xxx.xxx.xxx 5633 192.168.1.2 netmask 255.255.255.255 0
static (inside,outside) udp 5634 xxx.xxx.xxx.xxx 5634 192.168.1.2 netmask 255.255.255.255 0
static (inside,outside) tcp 5631 xxx.xxx.xxx.xxx 5631 192.168.1.15 netmask 255.255.255.255 0
static (inside,outside) udp 5632 xxx.xxx.xxx.xxx 5632 192.168.1.15 netmask 255.255.255.255 0
Now, when ever I try to enter these in, I get maximum number of connections should lie between 0 and 65535. I thought I specified that already
We have it working if we just want to get into the server using this
static (inside,outside) xxx.xxx.xxx.xxx 192.168.1.2 netmask 255.255.255.255 0 0
What am I doing wrong??
Any help wil be appreciated
aacole
Level 5
Level 5
The command syntax should be:
static (inside,outside) tcp xxx.xxx.xxx.xxx 5633 192.168.1.2 5633 netmask 255.255.255.255 0 0
static (inside,outside) tcp xxx.xxx.xxx.xxx 5631 192.168.1.15 5631 netmask 255.255.255.255 0 0
So when you connect to xxx.xxx.xxx.xxx 5633 you get re-directed to 192.168.1.2 5633 and 192.168.1.15 for connections to port 5631.
Not applicable
Can this be done when the outside address us configured for dynamic addressing? If so can you give me the syntax.
Shawna
