Pix question
kefah
I want to add another global outside ip address in pix firewall for outlook web server, basically i want to seperate exchange server and outlook web in different machines, outlook web & exchange Servers are intsalled inside the network, I also want alow outside users to access their e-mails connecting with any internet provider thru outlook web, so this would be like this???
static (inside,outside) 212.x.x.10 192.168.0.30 netmask 255.255.255.255. 0.0 (is this correct)
conduit permit tcp host 192.168.0.30 any
conduit permit tcp host 212.x.x.10 any
Please help!!!
bducharm
This is what you can do. Have a static and conduit pair for each server. If your exchange server was 192.168.0.30 and your outlook web server was 192.168.0.31, then do this:
static (inside,outside) 212.X.X.10 192.168.0.30
static (inside,outside) 212.X.X.11 192.168.0.31
conduit permit tcp host 212.X.X.10 eq (protocol) any
conduit permit tcp host 212.X.X.11 eq (protocol) any
The (protocol) would be smtp, http, etc., whatever you want to permit to get to that server.
kefah
Thanks for your reply, just a quick question, Is it really require to restart the pix firewall to take effect the new settings??
another question is defining static map for INSIDE/DMZ/OUTSIDE should be in sequence or it does not mater whatever sequence you make.
for example
static (inside, DMZ)
static (inside)
static (inside,outisde)
see above it is not in sequence i have the same case, I applied the settings you have suggested but it is not even ping to that IP from outside ...
please suggest!!!
The pix will allow outbound icmp packets from a higher security interface to a lower security interface, as long as you have a translation. In your case, if the static (inside, outside) statement is correct, then it will allow the echo request to go out.
The echo reply (the response to your ping) will, by default, be dropped by the pix. To allow it to return, you will need to apply a conduit or an ACL specifically permitting it.
For test purposes, you can apply a conduit permit icmp any any.
I recommend that you refer to the command reference for further clarification of the use of the commands.
http://www.cisco.com/univercd/cc/td/doc/product/iaabu/pix/pix_60/config/commands.htm
Hope this helps
Jeff
