07-14-2003 03:40 AM - edited 02-20-2020 10:51 PM
Hai,
We have a PIX connected to a router over GE.
Now we have to move our PIX to another building.
The distances between the PIX and the router will be over 100 mtrs.
I did not found an Single Mode GE interface for the PIX.
Does anyone have a solution for our problem?
07-15-2003 05:57 AM
There are many vendors like Black Box that have convertors for MM to SM and vice-versa. You will need to get this as the PIX has only MM interface.
yatin
07-16-2003 10:58 PM
Yatin,
Thanks for your answer.
Do you have any experience with that solution.
Can you suggest a device.
