Community Member
PIX restricted unit to be used as failover with a PIX UR unit
Is there anyone out there..that knows for sure that a PIX515e-R can be downgraded to a FO status....so that the pix can be used for Failover with an UR PIX that is identical...I've checked for the past two years and noone seems to have an answer...or a process..or a testimony....thanks
1 REPLY
Community Member
Re: PIX restricted unit to be used as failover with a PIX UR uni
Did you ask Cisco if they will supply a new activation key? That's the only way it will work. I don;t know if there are hardware restrictions, but I suspect that it's driven by the activation key.
104
