Community Member
PIX Running Secure VPN Client and VPN 3000 Client
Does anyone know if you can run both the VPN 3000 Client and the Cisco Secure VPN Client on the same PIX at the same time?
Also - what are the Licencing rules for running the VPN 3000 Client with a PIX?
1 REPLY
Community Member
Re: PIX Running Secure VPN Client and VPN 3000 Client
yes. See: http://www.cisco.com/warp/customer/110/dynamicpix.html
The configuration for the 2.x client is the same as the 1.1 (you don't need vpngroup configuration for the 1.1, but you need it for the 2.x and 3.x VPN 3000 client)
The client is available on CCO with your login - there are available at no cost to our customers with software download rights.
114
