pix site-to-site vpn problems
Please can someone help with a number of issues I am having with my pix515, when trying to configure a vpn to a checkpoint firewall. My pix has 16MB flash, 64MB RAM, 6.2.2 code and is running LAN-based failover. I have 6 interfaces, 5 of which are in use. I tried configuring a vpn to a checkpoint firewall to permit a single host on the Pix inside to access a single host on the cp inside network. I want to use NAT so did this using a static mapping. As soon as I applied the crypto map to the outside interface, the pix stopped passing all traffic out of the outside interface, including direct internet traffic.
I backed out and tried implementing the vpn with no nat using the nat 0 command. This had no impact on the operation of the pix however I could not get the vpn to kick into life (i.e. no isakmp or ipsec debug whatsoever). I then removed the nat 0 command and replaced it with "sysopt ipsec pl-compatible" now my vpn is working to some extent. The pix inside host can ping the cp inside host. However, the cp inside host can't ping the pix inside host. I think this is a config issue because I am seeing "proxy identities not supported" in the ipsec debug. I am continuing to work on this with the cp guys.
Ultimately however, I need to re-introduce nat but I am a bit wary after the previous problem. I am also seeing some other causes for concern. Firstly, the pix appears to failover for no apparent reason (I plan to implement logging to a syslog server to try to determine the cause of this). Also, when I was telnetted into the pix, it would not display back ipsec debugging (I had issued term mon). I checked using debug icmp and issuing pings and could see this fine.
Any help would be greatly appreciated.
Tracey
Re: pix site-to-site vpn problems
There is so much going on here that it would be hard to determine exactly what is happening without a config.
Is the CP side doing nat and IPSEC as well? I am guessing that there is some mismatch in the CP objects and the NAT/Interesting traffic of the Pix.
Also .. don't use sysopt pl-compatible :) Figure out what the problem is that causes it not to work using either nat 0 and sysopt connection permit ipsec / acls on the outside interface.
Thanks for your reply. I appreciate there is a lot going on. I have included the current config (with public addresses replaced) to help clarify:
PIX Version 6.2(2)
nameif ethernet0 outside security0
nameif ethernet1 inside security100
nameif ethernet2 WAN_Access security10
nameif ethernet3 Support security15
nameif ethernet4 DMZ security20
nameif ethernet5 Failover security25
enable password zDU4/BGnunLgHqiX encrypted
passwd zDU4/BGnunLgHqiX encrypted
hostname Primary-PIX
domain-name ciscopix.com
fixup protocol ftp 21
fixup protocol http 80
fixup protocol h323 h225 1720
fixup protocol h323 ras 1718-1719
fixup protocol ils 389
fixup protocol rsh 514
fixup protocol rtsp 554
fixup protocol smtp 25
fixup protocol sqlnet 1521
fixup protocol sip 5060
fixup protocol skinny 2000
names
access-list support_acl permit icmp host 192.168.1.1 any
access-list support_acl permit tcp host 192.168.1.1 host 192.168.1.254 eq telnet
access-list support_acl permit tcp host 192.168.1.1 host 192.168.1.254 eq https
access-list support_acl permit tcp host 192.168.1.1 16.0.0.0 255.255.255.0 eq lp
d
access-list support_acl permit tcp host 192.168.1.1 17.0.0.0 255.255.255.0 eq lp
d
access-list support_acl permit tcp host 192.168.1.1 18.0.0.0 255.255.255.0 eq lp
d
access-list support_acl permit tcp host 192.168.1.1 19.0.0.0 255.255.255.0 eq lp
d
access-list support_acl permit tcp host 192.168.1.1 132.147.161.0 255.255.255.0
eq lpd
access-list support_acl permit tcp host 192.168.1.1 192.168.98.0 255.255.255.0 e
q telnet
access-list support_acl permit tcp host 192.168.1.1 host 192.168.2.253 eq telnet
access-list support_acl permit tcp host 192.168.1.1 host 192.168.2.254 eq telnet
access-list support_acl deny ip any any
access-list WAN_Access_acl permit tcp 16.0.0.0 255.255.255.0 host 192.168.2.2 eq
telnet
access-list WAN_Access_acl permit tcp 17.0.0.0 255.255.255.0 host 192.168.2.2 eq
telnet
access-list WAN_Access_acl permit tcp 18.0.0.0 255.255.255.0 host 192.168.2.2 eq
telnet
access-list WAN_Access_acl permit tcp 19.0.0.0 255.255.255.0 host 192.168.2.2 eq
telnet
access-list WAN_Access_acl permit tcp 132.147.161.0 255.255.255.0 host 192.168.2
.2 eq telnet
access-list WAN_Access_acl permit icmp any any echo-reply
access-list WAN_Access_acl permit icmp any any time-exceeded
access-list WAN_Access_acl permit icmp 192.168.98.0 255.255.255.0 host 192.168.2
.2
access-list WAN_Access_acl permit tcp 192.168.98.0 255.255.255.0 host 192.168.2.
2 eq ftp
access-list WAN_Access_acl permit tcp 192.168.2.8 255.255.255.248 host 192.168.2
.2 eq telnet
access-list WAN_Access_acl deny ip any any
access-list To_Internet permit tcp 10.1.254.0 255.255.255.240 any eq www
access-list To_Internet permit tcp 10.1.254.0 255.255.255.240 any eq 8080
access-list To_Internet permit tcp 10.1.254.0 255.255.255.240 any eq telnet
access-list To_Internet permit tcp 10.1.254.0 255.255.255.240 any eq domain
access-list To_Internet permit tcp 10.1.254.0 255.255.255.240 any eq 9002
access-list To_Internet permit udp 10.1.254.0 255.255.255.240 any eq domain
access-list To_Internet permit icmp any any
access-list To_Internet permit tcp 10.1.254.0 255.255.255.240 any eq https
access-list To_Internet permit tcp 10.1.254.0 255.255.255.240 any eq smtp
access-list To_Internet permit tcp 10.1.254.0 255.255.255.240 any eq 3101
access-list To_Internet permit tcp 10.1.254.0 255.255.255.240 any eq ftp
access-list To_Internet deny ip any any
access-list From_Internet permit tcp any host mailserver eq smtp
access-list From_Internet permit icmp any any echo-reply
access-list From_Internet permit tcp host external host sftpserver eq
ssh
access-list From_Internet deny ip any any
access-list 101 permit ip host 10.1.254.8 host A.B.C.D
pager lines 200
logging console debugging
interface ethernet0 100full
interface ethernet1 auto
interface ethernet2 auto
interface ethernet3 auto
interface ethernet4 auto shutdown
interface ethernet5 auto
mtu outside 1500
mtu inside 1500
mtu WAN_Access 1500
mtu Support 1500
mtu DMZ 1500
mtu Failover 1500
ip address outside W.X.Y.Z 255.255.255.240
ip address inside 10.1.254.9 255.255.255.240
ip address WAN_Access 192.168.2.250 255.255.255.0
ip address Support 192.168.1.254 255.255.255.0
ip address DMZ 172.16.254.121 255.255.255.248
ip address Failover 172.16.254.33 255.255.255.248
ip verify reverse-path interface outside
ip verify reverse-path interface inside
ip verify reverse-path interface WAN_Access
ip verify reverse-path interface Support
ip verify reverse-path interface DMZ
ip verify reverse-path interface Failover
ip audit info action alarm
ip audit attack action alarm
failover
failover timeout 0:00:00
failover poll 15
failover ip address outside S.T.U.V
failover ip address inside 10.1.254.10
failover ip address WAN_Access 192.168.2.251
failover ip address Support 192.168.1.253
failover ip address DMZ 172.16.254.122
failover ip address Failover 172.16.254.34
failover link Failover
failover lan unit primary
failover lan interface Failover
failover lan key ********
failover lan enable
pdm location 192.168.1.1 255.255.255.255 Support
pdm history enable
arp timeout 14400
global (outside) 1 E.F.G.H I.J.K.L netmask 255.255.255.240
global (outside) 1 M.N.O.P netmask 255.255.255.240
nat (inside) 1 10.1.254.0 255.255.255.240 0 0
static (Support,WAN_Access) 192.168.2.2 192.168.1.1 netmask 255.255.255.255 0 0
static (inside,outside) 1.1.1.1 10.1.254.11 netmask 255.255.255.255 0 0
static (inside,outside) 2.2.2.2 10.1.254.8 netmask 255.255.255.255 0 0
access-group From_Internet in interface outside
access-group To_Internet in interface inside
access-group WAN_Access_acl in interface WAN_Access
access-group support_acl in interface Support
route outside 0.0.0.0 0.0.0.0 3.3.3.3 1
route WAN_Access 16.0.0.0 255.255.255.0 192.168.2.254 1
route WAN_Access 17.0.0.0 255.255.255.0 192.168.2.254 1
route WAN_Access 18.0.0.0 255.255.255.0 192.168.2.254 1
route WAN_Access 19.0.0.0 255.255.255.0 192.168.2.254 1
route WAN_Access 132.147.161.0 255.255.255.0 192.168.2.254 1
route WAN_Access 192.168.98.0 255.255.255.0 192.168.2.253 1
timeout xlate 3:00:00
timeout conn 2:00:00 half-closed 0:10:00 udp 0:02:00 rpc 0:10:00 h323 0:05:00 si
p 0:30:00 sip_media 0:02:00
timeout uauth 0:05:00 absolute
aaa-server TACACS+ protocol tacacs+
aaa-server RADIUS protocol radius
aaa-server LOCAL protocol local
aaa authorization command LOCAL
http server enable
http 192.168.1.1 255.255.255.255 Support
no snmp-server location
no snmp-server contact
snmp-server community public
no snmp-server enable traps
floodguard enable
sysopt connection permit-ipsec
no sysopt route dnat
crypto ipsec transform-set myset esp-des esp-md5-hmac
crypto map BPB 10 ipsec-isakmp
crypto map BPB 10 match address 101
crypto map BPB 10 set peer 4.4.4.4
crypto map BPB 10 set transform-set myset
crypto map BPB 10 set security-association lifetime seconds 3600 kilobytes 46080
00
crypto map BPB interface outside
isakmp enable outside
isakmp key ******** address 4.4.4.4 netmask 255.255.255.255
isakmp identity address
isakmp policy 1 authentication pre-share
isakmp policy 1 encryption des
isakmp policy 1 hash md5
isakmp policy 1 group 2
isakmp policy 1 lifetime 86400
telnet 192.168.1.1 255.255.255.255 Support
telnet timeout 5
ssh timeout 5
username admin password x5UicjfqZ4wWFwMV encrypted privilege 15
privilege show level 0 command version
privilege show level 0 command curpriv
privilege show level 3 command pdm
privilege show level 3 command blocks
privilege show level 3 command ssh
privilege configure level 3 command who
privilege show level 3 command isakmp
privilege show level 3 command ipsec
privilege show level 3 command vpdn
privilege show level 3 command local-host
privilege show level 3 command interface
privilege configure level 3 command ping
privilege configure level 5 mode enable command configure
privilege show level 5 command running-config
privilege show level 5 command privilege
privilege show level 5 command clock
privilege show level 5 command ntp
terminal width 80
Cryptochecksum:9de58c286a56bb9de9787cf9443db8de
As mentioned, I think I still have a config mismatch between the Pix and CP which I am working on. However, I am more concerned about how to get the vpn working with nat (and also why this previously caused the pix to stop passing traffic over the outside interface). With the nat config, I did not have the "no sysopt ipsec pl-compatible". The pix inside device is 10.1.254.8, which is statically mapped to a registered address. ACL 101 defines the traffic permitted down the tunnel. The CP is not doing nat.
Tracey
Tracy,
You have an interesting problem here and I would not be surprised if it come out in the CCIE lab.
Now I can not help you much with the CP, but take a look at the following:
1. I will use the static statement
2. Since for outbound traffic, NAT occurs before IPSEC, you will have to change your Crypto ACL to trigger IPSEC.
access-list 101 permit ip 2.2.2.2 X.X.X.X
Keep in mind that the only traffic that will be encrypted will be controlled by the ACL applied to the inside interface.
I didn't see anything "wrong" per say in your pix configuration. Usually what causes the Pix to stop passing all traffic when you apply a crypto map is if you have an incomplete crypto map or make changes with a crypto map applied.
What version of CP are you using ? 4.1 or NG? If NG are you using the Community Traffic Security Policy Accept all encrypted traffic? I have seen this cause many problems when not going to another CP.
Thanks for the info. I believe my crypto map was complete however, I was making a lot of changes and it could be that I made some while the crypto map was applied. The CP is NG. I will check with the person responsible for configuring the CP if the Community Traffic Security Policy Accept All Encrypted Traffic is set. The problem I have is that the CP is already supporting a number of operational vpns so we are unable change some of the global settings.
Thanks again,
Tracey
Thanks for the info. I will bear that in mind when doing further work on this. I hope to get downtime soon to have another go.
Tracey
212
