02-23-2004 05:10 AM - edited 02-20-2020 11:15 PM
What's the difference between xlate and conn timeout? If xlate timeout is 3 hours and conn timeout is 1 hour. An idle tcp connection will always be timed out by conn timeout? Am I wrong?
Best Regards.
02-26-2004 11:54 AM
An xlate is a dynamic NAT, a conn is a tcp connection. You always want the xlate timeout value to be higher than the conn timeout. And you are correct, the idle tcp will be terminated by the conn timeout. Once the xlate timeout expires, the inside IP can/will be nat'd to a different global IP next time it issues new traffic.
03-01-2004 01:34 AM
OK then, if TCP (conn) times out, does PIX silently erase this conn from the table and refuse additional TCP segments of this conn? OR informs parties involved in TCP connection?
Regards.
03-01-2004 04:18 AM
it silently discard the connection. There are no RST send to source/destination. The role is to clear from memory "dead" connections. A normal terminated connection (rst-rstack) is cleared from pix memory at that time. This timeout should not be set to low cause it will kill long ftp transfers and so on.
Timeout for xlate clear also all reference about a host including up connections.
