Community Member
PIX to 3030 L2L - No traffic past 3030
I've configured a L2L tunnel between a PIX 515 and a Cisco 3030 but I'm unable to ping or access anything other than the 3030 interfaces.
The tunnel comes up and looks functional. I referenced http://www.cisco.com/warp/public/471/ALTIGA_pix.html for the config. please help ---Mike
1 REPLY
Re: PIX to 3030 L2L - No traffic past 3030
This looks like a routing issue.
Possibly your default gateway settings for host behind the 3030 is not the 3030 privtate interface.
Check if the host behind the 3030 has a route for the subnet behind the pix that is set to be sent to the 3030 privtae interface.
On a windows pc, you can do a route add ....... for the pix private network with gateway of the 3030 private.
98
