Community Member
pix to check point vpn help
All, I need some help. Im trying to do a site to site vpn from my pix 515 with version 7.2 code on it to a check point firewall version R54. Can you guys check my config on the Pix side to make sure it looks ok? Im getting traffic one way only, and not the other way. In other words, from Pix site, I can ping a device at the check point site, but from the check point site, I can not ping anything from the pix side. A little help would be appreciated.
Bronze
Re: pix to check point vpn help
Refer to Configuring an IPSec Tunnel Between a Cisco Secure PIX Firewall and a Checkpoint NG Firewall document for more information
http://www.cisco.com/en/US/tech/tk583/tk372/technologies_configuration_example09186a00800ef796.shtml
Probably, if you use PIX version 7.2 for the same configuration of checkpoint is compatible.
Community Member
Thanks. re-created check point side and it works. thanks for the link.
147
