10-15-2003 10:23 AM - edited 02-21-2020 12:49 PM
I setup a site-site VPN between PIX on my end and a IBM OS/390 on the other end. I also have a dynamic VPN setup for remote users. The dynamic VPN is working fine . I have a problem with the site-site VPN in that when I initiate the tunnel , it works but when the other end tries it , it does not work. However , the thing I find interesting is that I have included the address of the outside interface on the PIX as part of the interesting traffic , and when the other end initiates a tunnel to the outside interface that works but not to the inside host.I tried a lot of things like changing lifetime, removing NAT eeven thouhgh I'm using NAT 0 . I had the inside and outside addresses translated to be the same. I have no clue now on how to make this work. I have attached a sample config which is similar to the one I use.
x.x.12.3 is the OUTSIDE interface and the other end is y.y.4.9.The host to which y.y.4.9 needs to connect is x.x.84.9
Thanks ,
Karthik.
access-list WRAIR permit ip host x.x.49.100 x.x.110.0 255.255.255.0
access-list WRAIR permit ip host x.x.68.218 x.x.110.0 255.255.255.0
access-list WRAIR permit ip host x.x.84.9 host y.y.4.9
access-list MEPCOM permit ip host x.x.12.3 host y.y.4.9
access-list MEPCOM permit ip host x.x.84.9 host y.y.4.9
nat 0 access-list WRAIR
ip local pool WRAIRPOOL x.x.110.2-x.x.110.20
aaa-server TACACS+ protocol tacacs+
aaa-server RADIUS protocol radius
aaa-server LOCAL protocol local
aaa-server partnerauth protocol radius
aaa-server partnerauth (dmz) host x.x.101.6 ******* timeout 5
aaa-server authinbound protocol radius
aaa-server authinbound (dmz) host x.x.101.6 ******* timeout 5
sysopt connection permit-ipsec
no sysopt route dnat
crypto ipsec transform-set WRAIRSET esp-3des esp-sha-hmac
crypto dynamic-map WRAIRDYN 1000 set transform-set WRAIRSET
crypto map WRAIRMAP 20 ipsec-isakmp
crypto map WRAIRMAP 20 match address MEPCOM
crypto map WRAIRMAP 20 set peer y.y.4.9
crypto map WRAIRMAP 20 set transform-set WRAIRSET
crypto map WRAIRMAP 1000 ipsec-isakmp dynamic WRAIRDYN
crypto map WRAIRMAP client authentication partnerauth
crypto map WRAIRMAP interface outside
isakmp enable outside
isakmp key ******** address y.y.4.9 netmask 255.255.255.255 no-xauth no-config-mode
isakmp identity address
isakmp policy 5 authentication pre-share
isakmp policy 5 encryption 3des
isakmp policy 5 hash sha
isakmp policy 5 group 2
isakmp policy 5 lifetime 86400
isakmp policy 10 authentication pre-share
isakmp policy 10 encryption 3des
isakmp policy 10 hash sha
isakmp policy 10 group 2
isakmp policy 10 lifetime 28800
vpngroup WRAIR address-pool WRAIRPOOL
vpngroup WRAIR idle-time 1800
vpngroup WRAIR password ********
10-20-2003 11:13 AM
Just try if it works when you increase xauth timer.
