Community Member
Pix-to-Pix IPSec is OK, but I have routing problems!
I have Pix2Pix IPSec which works fine but there are some routing issues.
Pix 1 inside - 192.168.31.1
Pix 1 outside - 172.16.1.2
Internet (IPSec tunnel)
Pix 2 outside - 172.17.1.2
Pix 2 inside - 10.51.2.2
Router at site 2 (eth0) - 10.51.2.1
Router at site 2 (eth1) - 10.100.1.1
Routes:
Pix 1 - 0.0.0.0 0.0.0.0 172.16.1.1
Pix 2 - 0.0.0.0 0.0.0.0 172.17.1.1
Pix 2 - 10.100.1.0 255.255.255.0 10.51.2.1
How do I tell Pix 1 how to get to 10.100.1.0 network???
Community Member
Re: Pix-to-Pix IPSec is OK, but I have routing problems!
Strangely enough it will not be a route.
It should be in the access-list that you use to get traffic from pix 1 to 10.51.2 network. The access-list will recognize the "route" and tunnel it to the other pix. At that point it's up to pix 2 to route it on its inside net.
Don't forget to setup the access-list in reverse on pix 2 to allow the 10.100.1.0 traffic from pix 1.
Community Member
Thanks .... I had a panic atack that evening .... the router belongs to somebody else ... and they "forgot" to amend the routes on it .....
84
