yeo
PIX to PIX VPN and VPN client to PIX VPN on same interface
I have a PIX 515 that has a current and working setup for VPN for our laptops on travel. Works great. Here is config:
access-list 110 permit ip x.x.x.128 255.255.255.128 192.168.110.0 255.255.255.0
sysopt connection permit-ipsec
crypto ipsec transform-set myset esp-des esp-md5-hmac
crypto dynamic-map dynmap 10 set transform-set myset
crypto map mymap 10 ipsec-isakmp dynamic dynmap
crypto map mymap interface outside
isakmp enable outside
isakmp identity address
isakmp policy 10 authentication pre-share
isakmp policy 10 encryption des
isakmp policy 10 hash md5
isakmp policy 10 group 2
isakmp policy 10 lifetime 86400
vpngroup vpn3000 address-pool vpnpool
vpngroup vpn3000 dns-server adc001
vpngroup vpn3000 default-domain yeo.org
vpngroup vpn3000 split-tunnel 110
vpngroup vpn3000 idle-time 1800
vpngroup vpn3000 password ********
This works great but I am trying to add a PIX to PIX VPN using a PIX 501 and the same PIX 515. The above config uses a dynamic crypto map function. The PIX to PIX does not call for this and when I try to use the same transform set for the PIX to PIX that I have for the client to PIX VPN, the PIX to PIX VPN doesnt work. Here is the config for the PIX to PIX VPN:
access-list 150 permit ip 172.16.1.0 255.255.255.0 192.168.1.0 255.255.255.0
nat (inside) 0 access-list 150
crypto ipsec transform-set newset esp-des esp-md5-hmac
crypto map pixpixvpn 1 ipsec-isakmp
crypto map pixpixvpn 1 match address 150
crypto map pixpixvpn 1 set peer 66.92.150.51
crypto map pixpixvpn 1 set transform-set newset
crypto map pixpixvpn interface outside
isakmp key ********** address x.x.x.51 netmask 255.255.255.255
isakmp policy 1 authentication pre-share
isakmp policy 1 encryption des
isakmp policy 1 hash md5
isakmp policy 1 group 1
isakmp policy 1 lifetime 86400
I can only apply 1 transform-set to the outside interface. Therefore I can only have either the PIX to PIX VPN or the Client to PIX VPN. Does any one know a way around this? Is there a way to use a static crypto map for our mobile vpn client users? Can the PIX to PIX be setup with the dynamic crypto map?
1 REPLY
Re: PIX to PIX VPN and VPN client to PIX VPN on same interface
You're correct in the fact you can only have one crypto map on an interface. You have to combine your two crypto maps by giving them the same name but different instance numbers. You want something like the following:
crypto map mymap 1 ipsec-isakmp
crypto map mymap 1 match address 150
crypto map mymap 1 set peer x.x.150.51
crypto map mymap 1 set transform-set newset
Note the instance numbers of 1 and 10. Crypto maps are read from lowest number up, so the PIX-to-PIX tunnel portion of the crypto map will be read first, then if that doesn't match, instance 10 will be used, which since it maps to a dynamic map, will match on everything. Always make you dynamic crypto map the highest instance number, cause it's sort of a catch-all at the end to match everything that hasn't already been defined (like VPN clients).
Also change your isakmp command as follows:
isakmp key ********** address x.x.x.51 netmask 255.255.255.255 no-xauth no-config-mode
cause you don't want to do xauth or config mode for a PIX-to-PIX tunnel.
178
