PIX to PIX vpn problem
I have a problem with my PIX to PIX vpn, I have a working VPN with a crypto Map statment applyed to the outside interface and this is working fine with a no nat access-list in a DMZ, I want to add another VPN to the Firewall so I add the ACL for the no nat on the inside interface and then add the acl for the crypto map, all still working
I than add the no nat for the inside interface all still working
So it is tiem to add the Crypto maps
i have to add these to excisting ones with a diff priority number as soon as i put them in the config the Firewall stopr working and need rebooting
Please help
Cheers
Rick
Re: PIX to PIX vpn problem
You have to unmap the crypto map from the interface before modifying the crypto maps. Also make sure you have all the elements for a crypto map, or else all hell breaks loose, or should I say no communications through the pix.
I have a text file that unmaps the crypto map then deletes the crypto map then recreate the crypto map with the changes and remaps the crypto map again. This all happens so fast that nothing disconnects. here is an example.
no crypto map vpn-map interface outside
crypto map vpn-map 10 ipsec-isakmp
crypto map vpn-map 10 match address (access-list)
crypto map vpn-map 10 set peer xxx.xxx.xxx.xxx
crypto map vpn-map 10 set transform-set 3set
crypto map vpn-map 11 ipsec-isakmp
crypto map vpn-map 11 match address (access-list)
crypto map vpn-map 11 set peer xxx.xxx.xxx.xxx
crypto map vpn-map 11 set transform-set 3set
crypto map vpn-map 18 ipsec-isakmp dynamic remote
Hope that helps
Thanks for your help I wil give it a try this morning I was going mad so if this fixes my problem I owe you a drink :-)
I will let you know
Rick.
I will let you know
Rick.
It worked thank you 4 your help ;-)
I was well stuck thasnk again.
Cheers.
Rick ;-)
120
