PIx to Pix VPN using DHCP
I have been looking at this document "http://www.cisco.com/warp/public/110/dynamicpix.html".
It suggests that you can setup a VPN connection that is initiated from one end only due to not knowing one of the ip addresses.
I have gone through the config and on the remote pix the external interface is setup for dhcp. Then Nat and the default route point to 204 net. How can this work if the interface is un-numbered?
ip address outside dhcp
global (outside) 1 204.1.1.10-204.1.1.15
route outside 0.0.0.0 0.0.0.0 204.1.1.2 1
1 REPLY
Bronze
Re: PIx to Pix VPN using DHCP
I think it probably should look something like this..
ip address outside dhcp setroute
global (outside) 1 interface
nat (inside) 0 access-list 101
93
