PIX to VPN Concentrator problem
I am having a problem with a pix to VPN concentrator. Phase one gets to the MMKEY_EXCH stage and then drops. Output from the log of the concentrator below:
IKEDBG/65 RPT=52 <ip address> Group [<ipaddress>] IKE MM Initiator FSM error history (struct &0x3c51900) <state>, <event>: MM_DONE, EV_ERROR MM_WAIT_MSG6, EV_RESEND_MSG MM_WAIT_MSG6, NullEvent MM_SND_MSG5, EV_SND_MSG
cheers
Kev
1 REPLY
Re: PIX to VPN Concentrator problem
Hi Kevin,
It seems that the preshared key is not matching. Please reconfigure it. Please also make sure that if any one end is behind a NAT/PAT device then we configure NAT-T. and that NAT/PAT device should allow the UDP 500 and UDP 4500 through it.
HTH,
Please rate if it helps.
Kamal
162
