PIX v7.x Nat and Globals with PAT
When using a Global statement with a single IP address which suggests PAT; 64,000 and 65,535 are sometimes listed as the upper limit of hosts. Are these theoretical numbers or what is the actual number of hosts that can be really used with a PAT address for PIX/ASA v7.x software?
Re: PIX v7.x Nat and Globals with PAT
Hi .. those limits are real and they are not related to the number of hosts a=but to the number os simultaneous connections been established.
I hope it helps .. pleae rate it if it does !!
Hi Fernando and thanks. Let me ask the question in a different way, maybe the answer is the same.
Which is it, 64,000 or 65,535?
What I want to know is how many host devices can use the PAT address is it 64,000 or 65,535 or some other number?
Or is it not a matter of the number of host devices that can use the PAT address but the number of ports available for connections?
Hi .. again is a matter of connections .. you could have 10 connections using differente ports and all initiated from the same IP address. It is not restriceted by the number of hosts.
I believe I read in a Cisco doc somewhere, they recomend that a single IP address using PAT should surfice for around 4000 hosts. This obviously depends of usage patterns...
547
