Pix VPN/Client acl question/problem
vachonb
Hey all,
I got something that I can't quite figure out...
Got a Pix setup to do VPN, 6.2(2). Inside is 192.168.10.x, VPN pool is 192.168.11.x. I can get the client to authenticate no prob, Inside machines can ping and communicate with the client with no prob. Client cannot ping, map or do anything inside without me adding a permit statement for 192.168.11.x to 192.168.10.x which is applied to the outside interface. Why do I need this statement ? Is there any way around this ? I think it is very un-secure to have to permit something like that on the outside interface, poses a huge security problem if you ask me. Below is a sanitized config.
Brian
Pix(config)# wr t
Building configuration...
: Saved
PIX Version 6.2(2)
nameif ethernet0 outside security0
nameif ethernet1 inside security100
enable password xxxxxxxxx encrypted
passwd xxxxxxxxx encrypted
hostname Pix
domain-name xxx.com
fixup protocol ftp 21
fixup protocol http 80
fixup protocol h323 h225 1720
fixup protocol h323 ras 1718-1719
fixup protocol ils 389
fixup protocol rsh 514
fixup protocol rtsp 554
fixup protocol smtp 25
fixup protocol sqlnet 1521
fixup protocol sip 5060
fixup protocol skinny 2000
names
access-list outside permit icmp any any echo-reply
access-list outside permit tcp any any eq pcanywhere-data
access-list outside permit udp any any eq pcanywhere-status
access-list outside permit ip 192.168.11.0 255.255.255.0 192.168.10.0 255.255.255.0
access-list nonat permit ip 192.168.10.0 255.255.255.0 192.168.11.0 255.255.255.0
pager lines 24
interface ethernet0 auto
interface ethernet1 auto
mtu outside 1500
mtu inside 1500
ip address outside dhcp setroute
ip address inside 192.168.10.1 255.255.255.0
ip audit info action alarm
ip audit attack action alarm
ip local pool ippool 192.168.11.1-192.168.11.254
pdm history enable
arp timeout 14400
global (outside) 1 interface
nat (inside) 0 access-list nonat
nat (inside) 1 192.168.10.0 255.255.255.0 0 0
static (inside,outside) tcp interface pcanywhere-data 192.168.10.2 pcanywhere-data netmask 255.255.255.255 0 0
static (inside,outside) udp interface pcanywhere-status 192.168.10.2 pcanywhere-status netmask 255.255.255.255 0 0
access-group outside in interface outside
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 rpc 0:10:00 h323 0:05:00 sip 0:30:00 sip_media 0:02:00
timeout uauth 0:05:00 absolute
aaa-server TACACS+ protocol tacacs+
aaa-server RADIUS protocol radius
aaa-server LOCAL protocol local
no snmp-server location
no snmp-server contact
snmp-server community public
no snmp-server enable traps
floodguard enable
no sysopt route dnat
crypto ipsec transform-set myset esp-des esp-md5-hmac
crypto dynamic-map dynmap 10 set transform-set myset
crypto map mymap 10 ipsec-isakmp dynamic dynmap
crypto map mymap interface outside
isakmp enable outside
isakmp identity address
isakmp policy 10 authentication pre-share
isakmp policy 10 encryption des
isakmp policy 10 hash md5
isakmp policy 10 group 2
isakmp policy 10 lifetime 86400
vpngroup xxxxx address-pool ippool
vpngroup xxxxxx dns-server 192.168.10.9
vpngroup xxxxx wins-server 192.168.10.9
vpngroup xxxxx default-domain bns.com
vpngroup xxxxx idle-time 1800
vpngroup xxxxx password ********
telnet timeout 5
ssh x.x.x.x x.x.x.x outside
ssh x.x.x.x x.x.x.x inside
ssh timeout 5
dhcpd address 192.168.10.50-192.168.10.100 inside
dhcpd dns xxx.xxx.xxx.xxx
dhcpd lease 3600
dhcpd ping_timeout 750
dhcpd domain xxx.com
dhcpd enable inside
terminal width 80
Cryptochecksum:133ccfbbecbe4ba44e6657280422c44b
: end
[OK]
Pix(config)#
vachonb
I figured it out. I missed "sysopt connection permit-ipsec". Which essentially tells the ipsec tunnel to disregard acl's.
Hopefully this will help someone else as well.
-Brian
