09-26-2003 05:50 AM - edited 02-21-2020 12:47 PM
Hello All,
I'm having a very hard time getting my PIX 515's to terminate point-to-point VPN tunnels. I'm using the free DES encryption and I don't even see the attempting IKE negotiations. I have tried setting this up with the VPN wizard within the PDM and my latest attempt is from the command line. However I did manage to get one of the 515s to terminate VPN connections from the Cisco VPN client version 4.0. Ive also run the several debugs and clear commands to force the pix to renegotiate phase 1 and 2 security associations. During the debugging I dont see anything, but I do see the VPN clients connections coming in. I have even tried without the client configuration statements, and obviously had no luck. Here are my PIX configuration lines below.
PIX Version 6.3(3)
interface ethernet0 auto
interface ethernet1 auto
nameif ethernet0 outside security0
nameif ethernet1 inside security100
enable password CENSORED encrypted
passwd CENSORED encrypted
hostname CENSORED
domain-name CENSORED
clock timezone EST -5
clock summer-time EDT recurring
fixup protocol dns maximum-length 512
fixup protocol ftp 21
fixup protocol h323 h225 1720
fixup protocol h323 ras 1718-1719
fixup protocol http 80
fixup protocol icmp error
fixup protocol ils 389
fixup protocol rsh 514
fixup protocol rtsp 554
fixup protocol sip 5060
fixup protocol sip udp 5060
fixup protocol skinny 2000
no fixup protocol smtp 25
fixup protocol sqlnet 1521
fixup protocol tftp 69
names
name 207.X.X.0 Netcom_Lan
name 68.X.X.5 Cisco_1720
name 203.X.X.111 RELAY-Taiwan
name 172.16.1.6 WIN2K_DOMAIN
name 172.16.1.5 MAIL_SERVER
name 172.16.1.4 IAS_SERVER
name 172.16.1.200 VIDEO_SERVER
access-list inbound permit tcp Netcom_Lan 255.255.255.0 host 12.X.X.198 eq 3389
access-list inbound deny ip host RELAY-Taiwan host 12.X.X.198
access-list inbound permit icmp any host 12.X.X.198
access-list inbound permit tcp any host 12.X.X.198 eq smtp
access-list inbound permit tcp any host 12.X.X.198 eq www
access-list inbound permit tcp Netcom_Lan 255.255.255.0 host 12.X.X.199 eq 3389
access-list inbound permit tcp any host 12.X.X.199 eq ftp-data
access-list inbound permit tcp any host 12.X.X.200 eq 6107
access-list inbound permit icmp any host 12.X.X.200 echo
access-list inbound remark Rule for Exchange server
access-list inbound remark Rule for the streaming video server
access-list inside_access_in permit ip any any
access-list inside_outbound_nat0_acl permit ip 172.16.1.0 255.255.255.0 192.168.100.0 255.255.255.192
access-list 100 permit ip 172.16.1.0 255.255.255.0 172.16.2.0 255.255.255.0
access-list 100 permit ip 172.16.1.0 255.255.255.0 192.168.100.0 255.255.255.0
access-list 110 permit ip 172.16.1.0 255.255.255.0 172.16.2.0 255.255.255.0
access-list vpn3000_splitTunnelAcl permit ip 172.16.1.0 255.255.255.0 any
pager lines 24
logging on
logging timestamp
logging console informational
logging monitor informational
logging buffered alerts
logging trap debugging
logging history informational
logging host inside IAS_SERVER format emblem
no logging message 106011
no logging message 710005
no logging message 111001
no logging message 111005
icmp permit any outside
icmp permit any inside
mtu outside 1500
mtu inside 1500
ip address outside 12.X.X.194 255.255.255.224
ip address inside 172.16.1.1 255.255.255.0
ip audit name Outbound-Info info action alarm drop
ip audit name Outbound-Attack attack action alarm drop
ip audit name Inbound-Attack attack action alarm drop reset
ip audit name Inbound-Info info action drop
ip audit interface outside Inbound-Info
ip audit interface outside Inbound-Attack
ip audit interface inside Outbound-Info
ip audit interface inside Outbound-Attack
ip audit info action alarm
ip audit attack action alarm
ip audit signature 2000 disable
ip audit signature 2001 disable
ip audit signature 2002 disable
ip audit signature 2003 disable
ip audit signature 2004 disable
ip audit signature 2005 disable
ip audit signature 2006 disable
ip audit signature 2007 disable
ip audit signature 2008 disable
ip audit signature 2009 disable
ip audit signature 2010 disable
ip audit signature 2011 disable
ip audit signature 2012 disable
ip local pool remote 192.168.100.1-192.168.100.254
arp timeout 14400
global (outside) 1 12.X.X.195
nat (inside) 0 access-list 100
nat (inside) 1 172.16.1.0 255.255.255.0 0 0
static (inside,outside) 12.X.X.198 MAIL_SERVER netmask 255.255.255.255 0 0
static (inside,outside) 12.X.X.199 WIN2K_DOMAIN netmask 255.255.255.255 0 0
static (inside,outside) 12.X.X.200 VIDEO_SERVER netmask 255.255.255.255 0 0
access-group inbound in interface outside
access-group inside_access_in in interface inside
route outside 0.0.0.0 0.0.0.0 12.X.X.193 1
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 rpc 0:10:00 h225 1:00:00
timeout h323 0:05:00 mgcp 0:05:00 sip 0:30:00 sip_media 0:02:00
timeout uauth 0:05:00 absolute
aaa-server TACACS+ protocol tacacs+
aaa-server RADIUS protocol radius
aaa-server LOCAL protocol local
aaa-server local protocol tacacs+
aaa-server partnerauth protocol radius
aaa-server partnerauth (inside) host IAS_SERVER CENSORED timeout 5
ntp server 16.X.X.4 source outside prefer
ntp server 140.X.X.34 source outside
http server enable
no snmp-server location
no snmp-server contact
snmp-server community CENSORED
no snmp-server enable traps
floodguard enable
sysopt connection permit-ipsec
crypto ipsec transform-set ESP-DES-MD5 esp-des esp-md5-hmac
crypto dynamic-map dynmap 30 set transform-set ESP-DES-MD5
crypto map newmap 10 ipsec-isakmp
crypto map newmap 10 match address 110
crypto map newmap 10 set peer 12.X.X.34
crypto map newmap 10 set transform-set ESP-DES-MD5
crypto map newmap 20 ipsec-isakmp dynamic dynmap
crypto map newmap interface outside
isakmp enable outside
isakmp key CENSORED address 12.X.X.34 netmask 255.255.255.255 no-xauth no-config-mode
isakmp identity address
isakmp keepalive 10
isakmp nat-traversal 20
isakmp policy 10 authentication pre-share
isakmp policy 10 encryption des
isakmp policy 10 hash md5
isakmp policy 10 group 2
isakmp policy 10 lifetime 86400
vpngroup vpn3000 address-pool remote
vpngroup vpn3000 dns-server WIN2K_DOMAIN
vpngroup vpn3000 wins-server WIN2K_DOMAIN
vpngroup vpn3000 default-domain CENSORED
vpngroup vpn3000 split-tunnel vpn3000_splitTunnelAcl
vpngroup vpn3000 split-dns CENSORED
vpngroup vpn3000 idle-time 1800
vpngroup vpn3000 password CENSORED
telnet timeout 5
ssh timeout 15
management-access outside
console timeout 0
terminal width 80
09-29-2003 05:48 AM
anyone?
10-05-2003 01:10 PM
Have you tried to take out the options "no-xauth no-config-mode" from the statements below. These are vpn client specific config options:
What is shown by: show isa sa detail,
debug crypto isakmp, shows the association attempts?
