PIX VPN Hub and Spoke
I have a PIX VPN hub and spoke configuration and I want to let the spokes communicate with eachother. In the documentation it says "The two outlying networks are not able to communicate with each other by going through the central PIX because the PIX does not route traffic received on one interface back out the same interface."
Can I use an router on the inside network to work around this limitation? If so, how sould I configure this?
All PIX firewalls are 506's so I cannot use PIX version 7.
Best regards, Frank
Gold
Re: PIX VPN Hub and Spoke
assuming a router is deployed on each site. a gre tunnel may be configured between the routers over the ipsec between the 506e.
Thanks for the reply but I had something else in mind.
What I want to do is place a router on the inside network of the hub.
I my opinion it should then be possible to direct VPN traffic comming from one spoke to the inside router (using a 'route inside 0 0 ' on the PIX). Next the router on the inside network sends traffic destined for the other spoke back to the PIX and the PIX sends it through a VPN to the other spoke.
Can this work?
92
