PIX VPN problem
I have configured a basic VPN on our corporate PIX and am using VPN Client 3.6 to connect. This works perfectly until I try and connect more than one client. Config to follow - any ideas?.......
access-list vpn-no-nat permit ip x.x.x.0 255.0.0.0 x.x.x.0 255.255.255.0
nat (inside) 0 access-list vpn-no-nat
ip local pool ippool x.x.x.1-15.15.15.4
aaa-server partnerauth protocol tacacs+
aaa-server partnerauth (inside) host x.xx.18.10 ************** timeout 10
sysopt connection permit-ipsec
crypto ipsec transform-set myset esp-des esp-md5-hmac
crypto dynamic-map dynmap 10 set transform-set myset
crypto map mymap 10 ipsec-isakmp dynamic dynmap
crypto map mymap client authentication partnerauth
crypto map mymap interface outside
isakmp enable outside
isakmp identity address
isakmp policy 10 authentication pre-share
isakmp policy 10 encryption des
isakmp policy 10 hash md5
isakmp policy 10 group 2
isakmp policy 10 lifetime 86400
vpngroup itsnetworksvpn address-pool ippool
vpngroup itsnetworksvpn dns-server x.x.3.1
vpngroup itsnetworksvpn wins-server x.x.203.2
vpngroup itsnetworksvpn idle-time 1800
vpngroup itsnetworksvpn password ********************
  • Other Security Subjects
1 REPLY
Re: PIX VPN problem
What happens when you connect more than one client?
Are these two clients behind the one router doing NAT/PAT? If so it's probably that the NAT/PAT device isn't NAT/PAT'ing the IPSec traffic properly. If the first one disconnects when the second one tries to connect then this is more than likely the problem, nothing to do with the PIX.
Try connecting from two different locations and see if that works.
83
