PIX VPNGROUP - Many users per group
When configure PIX to VPN client 3.x , we use the command vpngroup.
How about if I have 20 VPN client users, does it mean I need to create 20 vpngroup XX profile ?
Can we have multiple users in one group and assign individual user with unique username/password ?
Just like the vpndn command for PPTP.
Re: PIX VPNGROUP - Many users per group
You can certainly have more than one user per group. All you need to do is the following:
vpngroup address-pool ippool
vpngroup dns-server 10.1.1.2
vpngroup wins-server 10.1.1.2
vpngroup default-domain hp.com
vpngroup password
Then define the group in all your users VPn client connection profiles. To set up authentication locally on teh PIX, just add the following:
crypto map client authentication LOCAL
username password
You can have as many username/password combinations as you like.
The only thing you can't do is have one group use local authentication and another group use say, TACACS or Radius authentication, every group has to use the same authentication mechanism, but as I said, you can have one group or multiple groups, it's up to you.
Thanks a lot !
Best Regards.
138
