Community Member
PIX with AAA not validating new users from same NAT-domain
We're using a PIX 515R with a Microsoft webserver on HTTP and HTTPS. Users on this webserver have to authenticate with an cryptocard token.
The PIX is validating the user by checking the token on a cryptocard RADIUS server. This system works fine if you're not behind a proxyserver with NAT. If the clienst are behind a proxy/firewall server with NAT we encounter problems with authenticating each client seperate.
Once the first user is authenticated, every other user from behind the proxy server can connect trough the PIX with the webserver without authentication.
The log from the PIX and the configuration of the PIX are included below.
The log from the pix is as follows:
109001: Auth start for user '???' from to
109011: Authen Session Start: user 'gobo', sid 242
109005: Authentication succeeded for user 'gobo' from to on interface outside
302001: Built inbound TCP connection 47097 for faddr gaddr laddr (gobo)
302002: Teardown TCP connection 47097 faddr gaddr laddr duration 0:01:03 bytes 9364 (gobo)
302001: Built inbound TCP connection 47099 for faddr gaddr laddr (gobo) This user doesn't have to authenticate because the PIX firewall still thinks it's the first user (gobo)
Then request a webpage with first client (gobo)
302001: Built inbound TCP connection 47100 for faddr gaddr laddr (gobo)
302001: Built inbound TCP connection 47101 for faddr gaddr laddr (gobo)
And then the second client again (not authenticated, PIX thinks that this is client "gobo")
302001: Built inbound TCP connection 47102 for faddr gaddr laddr (gobo)
Th configuration looks like this:
: Saved
PIX Version 5.1(2)
nameif ethernet0 outside security0
nameif ethernet1 inside security100
enable password removed encrypted
passwd removed encrypted
hostname TLEUFFWR002
fixup protocol ftp 21
fixup protocol http 80
fixup protocol h323 1720
fixup protocol rsh 514
fixup protocol smtp 25
fixup protocol sqlnet 1521
name eufi_web_extern
name eufi_web_intern
access-list acl_out permit tcp any any eq www
access-list acl_out permit tcp any any eq 443
access-list acl_in permit ip any any
access-list acl_in permit tcp any any
access-list acl_in permit udp any any
access-list acl_in permit icmp any any
pager lines 24
logging on
no logging timestamp
no logging standby
no logging console
no logging monitor
logging buffered debugging
no logging trap
no logging history
logging facility 20
logging queue 4096
interface ethernet0 auto
interface ethernet1 auto
mtu outside 1500
mtu inside 1500
ip address outside
ip address inside
arp timeout 14400
nat (inside) 1 0 0
static (inside,outside) eufi_web_extern eufi_web_intern netmask 0 0 access-group acl_out in interface outside access-group acl_in in interface inside route outside 1 timeout xlate 3:00:00 conn 1:00:00 half-closed 0:10:00 udp 0:02:00 timeout rpc 0:10:00 h323 0:05:00 timeout uauth 3:00:00 absolute uauth 0:30:00 inactivity aaa-server TACACS+ protocol tacacs+
aaa-server RADIUS protocol radius
aaa-server RADIUS (inside) host eufi_web_intern Removed timeout 30 aaa authentication include http inbound RADIUS aaa authentication include tcp/443 inbound RADIUS no snmp-server location no snmp-server contact snmp-server community public no snmp-server enable traps floodguard enable isakmp identity hostname telnet timeout 5 terminal width 80 Cryptochecksum:f2650712cc168d0326178d6f8323a295
: end
