PIX with high CPU Utilisation - 6.3(5) Loosing pri / sec failover keepaliv
How can one tell which process is hogging the CPU?
Jun 26 10:45:14 brw01fwn02-fo.aus.hp.com Jun 26 2006 10:45:09: %PIX-1-105005: (Secondary) Lost Failover communications with mate on interface failover
Jun 26 10:45:15 brw01fwn02-fo.aus.hp.com Jun 26 2006 10:45:10: %PIX-1-105009: (Secondary) Testing on interface failover Passed
Jun 26 10:45:15 brw01fwn02-fo.aus.hp.com Jun 26 2006 10:45:10: %PIX-1-105005: (Secondary) Lost Failover communications with mate on interface inside
Jun 26 10:45:15 brw01fwn02-fo.aus.hp.com Jun 26 2006 10:45:10: %PIX-1-105008: (Secondary) Testing Interface inside
Jun 26 10:45:18 brw01fwn02-fo.aus.hp.com Jun 26 2006 10:45:13: %PIX-1-105009: (Secondary) Testing on interface inside Passed
Jun 26 10:45:33 brw01fwn02-fo.aus.hp.com Jun 26 2006 10:45:28: %PIX-1-105005: (Secondary) Lost Failover communications with mate on interface outside
Jun 26 10:45:33 brw01fwn02-fo.aus.hp.com Jun 26 2006 10:45:28: %PIX-1-105008: (Secondary) Testing Interface outside
Jun 26 10:45:39 brw01fwn02-fo.aus.hp.com Jun 26 2006 10:45:34: %PIX-1-105005: (Secondary) Lost Failover communications with mate on interface failover
Jun 26 10:45:41 brw01fwn02-fo.aus.hp.com Jun 26 2006 10:45:36: %PIX-1-105009: (Secondary) Testing on interface failover Passed
Jun 26 10:45:41 brw01fwn02-fo.aus.hp.com Jun 26 2006 10:45:36: %PIX-1-105005: (Secondary) Lost Failover communications with mate on interface inside
Jun 26 10:45:41 brw01fwn02-fo.aus.hp.com Jun 26 2006 10:45:36: %PIX-1-105008: (Secondary) Testing Interface inside
Jun 26 10:46:26 brw01fwn02-fo.aus.hp.com Jun 26 2006 10:46:22: %PIX-1-105005: (Secondary) Lost Failover communications with mate on interface failover
Jun 26 10:46:26 brw01fwn02-fo.aus.hp.com Jun 26 2006 10:46:22: %PIX-1-105008: (Secondary) Testing Interface failover
Jun 26 10:46:29 brw01fwn02-fo.aus.hp.com Jun 26 2006 10:46:24: %PIX-1-105009: (Secondary) Testing on interface failover Passed
Jun 26 10:46:30 brw01fwn02-fo.aus.hp.com Jun 26 2006 10:46:25: %PIX-1-105005: (Secondary) Lost Failover communications with mate on interface inside
Jun 26 10:46:43 brw01fwn02-fo.aus.hp.com Jun 26 2006 10:46:39: %PIX-1-105009: (Secondary) Testing on interface inside Passed
Jun 26 10:47:05 brw01fwn02-fo.aus.hp.com Jun 26 2006 10:47:00: %PIX-1-105005: (Secondary) Lost Failover communications with mate on interface outside
Jun 26 10:47:08 brw01fwn02-fo.aus.hp.com Jun 26 2006 10:47:04: %PIX-1-105009: (Secondary) Testing on interface outside Passed
Jun 26 10:47:16 brw01fwn02-fo.aus.hp.com Jun 26 2006 10:47:11: %PIX-1-105005: (Secondary) Lost Failover communications with mate on interface failover
Jun 26 10:47:16 brw01fwn02-fo.aus.hp.com Jun 26 2006 10:47:11: %PIX-1-105008: (Secondary) Testing Interface failover
Jun 26 10:47:24 brw01fwn02-fo.aus.hp.com Jun 26 2006 10:47:20: %PIX-1-105009: (Secondary) Testing on interface inside Passed
Jun 26 10:47:46 brw01fwn02-fo.aus.hp.com Jun 26 2006 10:47:41: %PIX-1-105005: (Secondary) Lost Failover communications with mate on interface outside
Jun 26 10:47:46 brw01fwn02-fo.aus.hp.com Jun 26 2006 10:47:41: %PIX-1-105008: (Secondary) Testing Interface outside
Jun 26 10:47:50 brw01fwn02-fo.aus.hp.com Jun 26 2006 10:47:45: %PIX-1-105009: (Secondary) Testing on interface outside Passed
Jun 26 10:47:57 brw01fwn02-fo.aus.hp.com Jun 26 2006 10:47:52: %PIX-1-105005: (Secondary) Lost Failover communications with mate on interface failover
Jun 26 10:47:57 brw01fwn02-fo.aus.hp.com Jun 26 2006 10:47:52: %PIX-1-105008: (Secondary) Testing Interface failover
Re: PIX with high CPU Utilisation - 6.3(5) Loosing pri / sec fai
Problem happens for a duration of 2 to 3 minutes once a day around the same time of the day for the last 3 days.
I've seen this when traffic has been high. What does "show conn count" show at these times?
There are various debug commands and for me they showed dropped hellos on busy interfaces.
155
