06-14-2006 02:41 AM - edited 03-09-2019 03:14 PM
I configure pix501 win pc xp and std ip 192.168.1.1, my cfg is : inside 192.168.0.254, outside 10.0.0.1, gateway 10.0.0.250 . after cfg my pc is set with fixed ip, then I receive error when tryed access https://192.168.0.254/startup.html.
I tryed access to pix with com1, but my psw first char is "?" (shift+3) !! and it's impossible to reset with tera term emulator !
help me, please, thanks
06-14-2006 07:17 AM
It sounds like you need to perform a password recovery on the PIX. Here is a link to the instructions:
(Note that the URL probably wrapped.)
Hope this helps.
06-15-2006 12:30 AM
ok, i reset psw, now it's impossible to set ip inside 192.168.0.254 255.255.255.0, i receive error "Interface address is not on same subnet as DHCP pool
pixfirewall".
pixfirewall(config)# show configure
: Saved
: Written by enable_15 at 01:06:20.622 UTC Thu Jun 15 2006
PIX Version 6.3(5)
interface ethernet0 auto
interface ethernet1 100full
nameif ethernet0 outside security0
nameif ethernet1 inside security100
enable password xxx
passwd xxx
hostname pixfirewall
domain-name ciscopix.com
fixup protocol dns maximum-length 512
fixup protocol ftp 21
fixup protocol h323 h225 1720
fixup protocol h323 ras 1718-1719
fixup protocol http 80
fixup protocol rsh 514
fixup protocol rtsp 554
fixup protocol sip 5060
fixup protocol sip udp 5060
fixup protocol skinny 2000
fixup protocol smtp 25
fixup protocol sqlnet 1521
fixup protocol tftp 69
names
pager lines 24
mtu outside 1500
mtu inside 1500
ip address outside 10.0.0.1 255.255.255.0
ip address inside 192.168.1.1 255.255.255.0
ip audit info action alarm
ip audit attack action alarm
pdm logging informational 100
pdm history enable
arp timeout 14400
global (outside) 1 interface
nat (inside) 1 0.0.0.0 0.0.0.0 0 0
route outside 0.0.0.0 0.x.x.x.0.0.250 1
timeout xlate 0:05:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 rpc 0:10:00 h225 1:00:00
timeout h323 0:05:00 mgcp 0:05:00 sip 0:30:00 sip_media 0:02:00
timeout sip-disconnect 0:02:00 sip-invite 0:03:00
timeout uauth 0:05:00 absolute
aaa-server TACACS+ protocol tacacs+
aaa-server TACACS+ max-failed-attempts 3
aaa-server TACACS+ deadtime 10
aaa-server RADIUS protocol radius
aaa-server RADIUS max-failed-attempts 3
aaa-server RADIUS deadtime 10
aaa-server LOCAL protocol local
http server enable
http 192.168.1.0 255.255.255.0 inside
no snmp-server location
no snmp-server contact
snmp-server community public
no snmp-server enable traps
floodguard enable
telnet timeout 5
ssh timeout 5
console timeout 0
dhcpd address 192.168.1.2-192.168.1.33 inside
dhcpd lease 3600
dhcpd ping_timeout 750
dhcpd auto_config outside
terminal width 80
Cryptochecksum:xxxx
pixfirewall(config)# configure factory-default ip-address netmask
Invalid IP address ip-address
pixfirewall(config)# configure factory-default 192.168.0.254 255.255.255.0
Specified IP address (192.168.0.254) is not allowed; it would leave no room for
DHCP address pool.
pixfirewall(config)# show ip
System IP Addresses:
ip address outside 10.0.x.x.255.255.0
Current IP Addresses:
pixfirewall(config)# ip address inside 192.168.0.254 255.255.255.0
06-15-2006 07:00 AM
your DHCP is not on the same subnet as your interface, you need to change your ip address to 192.168.1.254 or change the dhcp leases to 192.168.0.2-192.168.0.33 255.255.255.0 subnet. or you could just change your subnet to 255.255.0.0 and that would work also.
