pix501 static port redirection
Hi!
I've really made some efforts in making this work but without any success.
What i'm trying to do is a port redirection on tcp 4899. I've searched forums, read articles and the manual but this really wont work.
Topology: ISP - DSL-modem - pix - lan
Here's the config which from my pov is working the "best".
: Saved
PIX Version 6.3(1)
interface ethernet0 auto
interface ethernet1 100full
nameif ethernet0 outside security0
nameif ethernet1 inside security100
enable password xxxx
passwd xxx
hostname pixfirewall
domain-name ciscopix.com
fixup protocol ftp 21
fixup protocol h323 h225 1720
fixup protocol h323 ras 1718-1719
fixup protocol http 80
fixup protocol ils 389
fixup protocol rsh 514
fixup protocol rtsp 554
fixup protocol sip 5060
fixup protocol sip udp 5060
fixup protocol skinny 2000
fixup protocol smtp 25
fixup protocol sqlnet 1521
names
access-list 101 permit tcp any host xx.xx.xx.245 eq 4899
pager lines 24
logging console informational
mtu outside 1500
mtu inside 1500
ip address outside xx.xx.xx.244 255.255.255.240
ip address inside 192.168.29.91 255.255.255.0
ip audit info action alarm
ip audit attack action alarm
pdm logging informational 100
pdm history enable
arp timeout 14400
global (outside) 1 xx.xx.xx.245
nat (inside) 1 0.0.0.0 0.0.0.0 0 0
static (inside,outside) tcp xx.xx.xx.245 4899 192.168.29.4 4899 netmask 255.255.255.255 0 0
access-group 101 in interface outside
route outside 0.0.0.0 0.0.0.0 xx.xx.xx.241 1
timeout xlate 0:05:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 rpc 0:10:00 h225 1:00:00
timeout h323 0:05:00 mgcp 0:05:00 sip 0:30:00 sip_media 0:02:00
timeout uauth 0:05:00 absolute
aaa-server TACACS+ protocol tacacs+
aaa-server RADIUS protocol radius
aaa-server LOCAL protocol local
http server enable
http 192.168.29.0 255.255.255.0 inside
no snmp-server location
no snmp-server contact
snmp-server community public
no snmp-server enable traps
floodguard enable
telnet timeout 5
ssh timeout 5
console timeout 0
dhcpd address 192.168.29.92-192.168.29.123 inside
dhcpd lease 3600
dhcpd ping_timeout 750
dhcpd auto_config outside
terminal width 80
Cryptochecksum:xxxx
: end
Here's a log of what's happening when i try to initiate a connection.
609001: Built local-host inside:192.168.29.4
305011: Built static TCP translation from inside:192.168.29.4/4899 to outside:xx.xx.xx.245/4899
302013: Built inbound TCP connection 582 for outside:yy.yy.yy.51/3289 (yy.yy.yy.51/3289) to inside:192.168.29.4/4899 (xx.xx.xx.245/4899)
302014: Teardown TCP connection 582 for outside:yy.yy.yy.51/3289 to inside:192.168.29.4/4899 duration 0:02:01 bytes 0 SYN Timeout
305012: Teardown static TCP translation from inside:192.168.29.4/4899 to outside:xx.xx.xx.245/4899 duration 0:02:15
And imo this looks like it should? But there are no dataflow.
Thanks! Peter
1 ACCEPTED SOLUTION
Silver
Re: pix501 static port redirection
are you sure the service is running on 192.168.29.4? "bytes 0 SYN Timeout " makes it seem like no reply was sent from the inside.
after adding the static statement, did you do a clear xlate or reboot the pix to reinitialize the translation slot table? (clear xlate is preferred, but naturally a reboot will wipe clean the table)
Silver
Yes i'm possitive the service is running. Haven't tested clear xlate but it's been rebooted for sure.
Thanks for your directions Matt!
I came up with this to be a problem with the inside host. The inside host was a not configured w2k clusteredserver in a labenvironment (2 nic's). The service was remote administrator. Haven't tested any other service portmapping to a 2nic host though.
158
