PIX501 to VPN3005 connection
Are there any good documents on the best way to setup a site-site VPN connection between and a PIX501 and VPN3005.
I have a small site where I will need to connect about 3 users to a pix501 and create a VPN tunnel back to our HQ(vpn3005).
I see a few options for doing this but I am looking for the best scenerio. I do want the pix501 to initiate the tunnel.
Thanks!
Re: PIX501 to VPN3005 connection
Here's a link on how to set this up.
http://www.cisco.com/warp/public/471/ALTIGA_pix.html
Kurtis Durrett
All the good documents on the VPN3000 are at
http://www.cisco.com/cgi-bin/Support/PSP/psp_view.pl?p=Hardware:Cisco_VPN_3000_Concentrator
One thing you will not find mentioned is how you will accesst the 501 from HQ. In a nut shell you need to build a second tunnel to the outside interface of the 501. On the PIX your ACL to define VPN traffic will have two lines one for the HQ LAN to the Remote site LAN and one for the HQ LAN to the outside interface ot the PIX. On the VPN3000 you make a network list that says the same thing. This will essentially build two tunnels between the devices. Oh and don't forget to all the appropriate "telnet <> outside" command so the PIX will allow the connection on the outside interface.
Thanks for the post back.
I am also experimenting with using the Easy VPN but can't seem to get it to work. On my concentrator I get a message saying
51087 11/25/2002 14:09:11.340 SEV=5 IKE/0 RPT=611 207.252.113.60
All IKE SA proposals found unacceptable!
51088 11/25/2002 14:09:11.340 SEV=4 IKEDBG/65 RPT=630 207.252.113.60
Group [kinder]
IKE AM Responder FSM error history (struct &0x1dc43a0)
AM_DONE, EV_ERROR
AM_BLD_MSG2, EV_PROCESS_SA
AM_BLD_MSG2, EV_GET_PFS
AM_BLD_MSG2, EV_GROUP_OK
My PIX501 doesn't have 3des enabled and I don't plan on using it. Is there something I am missing here?
I have made sure that all my group and user info is correct.
Here is what I have on my PIx box..
PIX Version 6.2(1)
nameif ethernet0 outside security0
nameif ethernet1 inside security100
enable password 8Ry2YjIyt7RRXU24 encrypted
passwd 2KFQnbNIdI.2KYOU encrypted
hostname pixfirewall
domain-name ciscopix.com
fixup protocol ftp 21
fixup protocol http 80
fixup protocol h323 h225 1720
fixup protocol h323 ras 1718-1719
fixup protocol ils 389
fixup protocol rsh 514
fixup protocol rtsp 554
fixup protocol smtp 25
fixup protocol sqlnet 1521
fixup protocol sip 5060
fixup protocol skinny 2000
names
pager lines 24
interface ethernet0 10baset
interface ethernet1 10full
mtu outside 1500
mtu inside 1500
ip address outside dhcp setroute
ip address inside 192.168.1.1 255.255.255.0
ip audit info action alarm
ip audit attack action alarm
pdm logging informational 100
pdm history enable
arp timeout 14400
global (outside) 1 interface
nat (inside) 1 0.0.0.0 0.0.0.0 0 0
timeout xlate 0:05:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 rpc 0:10:00 h323 0:05:00 si
p 0:30:00 sip_media 0:02:00
timeout uauth 0:05:00 absolute
aaa-server TACACS+ protocol tacacs+
aaa-server RADIUS protocol radius
aaa-server LOCAL protocol local
http server enable
http 192.168.1.0 255.255.255.0 inside
no snmp-server location
no snmp-server contact
snmp-server community public
no snmp-server enable traps
floodguard enable
no sysopt route dnat
telnet 192.168.1.0 255.255.255.0 inside
telnet timeout 5
ssh timeout 5
dhcpd address 192.168.1.2-192.168.1.33 inside
dhcpd lease 3600
dhcpd ping_timeout 750
dhcpd auto_config outside
dhcpd enable inside
vpnclient vpngroup kinder password ********
vpnclient username test password ********
vpnclient server 207.252.113.7
vpnclient mode client-mode
vpnclient enable
terminal width 80
Cryptochecksum:54589c10f447c9ec926729df49445c5e
: end
pixfirewall#
Thanks!
91
