PIX501 with Telewest Blueyonder DSL.
Please could anyone suggest why my PIX501 will not receive a DHCP assigned address to the Outside interface when plugged into a Telewest supplied Motorola SurfBoard Cable Modem?
I have registered the Outside interface MAC address with the Telewest Blueyonder so it should now be capable of receiving an IP address. PC's and my Linksys AP Router can receive IP addresses fine.
I am using the following commands for this:
ip address outside dhcp retry 4
and
dhcpd auto_config outside
When I show int, Ethernet0 is up and the line protocol is up, but no IP address is assigned. Sometimes I get a row of dot's along the command prompt and eventually "DHCP failed".
Many thanks
Max...
Silver
Re: PIX501 with Telewest Blueyonder DSL.
http://www.cisco.com/univercd/cc/td/doc/product/iaabu/pix/pix_sw/v_63/cmdref/c.htm#1053548
Check out the capture command. It is a built in packet capture utility in recent PIX OS revs. It will allow you to capture what is on the wire of the outside of your PIX - you can see if there is an dhcp server offering leases, etc.
Also, debug dhcpc has some options to crank up logging - you can use that to try to diagnose what is going on.
I am not familar with that specific cable company's operations, but did have similar problems when swapping out my cable modem - is that specific cable modem unit the one that successfully works with the linksys - i.e., you are only swapping in the pix for the linksys? Does telewest do any authentication - pppoe, etc?
Thanks for your reply. I wasn't familiar with the capture command so I will give that a go. I am running 6.3(1).
It is the same cable modem that works with my Linksys and also a PC NIC so I don't think it is faulty. I have tried swapping the cable and initial tests prove that Ethernet0 of the PIX is physically fine.
The cable modem presents as Ethernet without pppoe so I can literally plug in any Ethernet interface and providing I have registered it's MAC with Telewest it should receive a DHCP supplied address. There isn't any user authentication taking place.
Telewest Blueyonder Tech Support won't provide any support over this so any further suggestions from you guys would be appreciated.
Cheers
Max...
Here is a sample of the debugs with debug dhcpc packet, debug dhcpc error and debug dhcpc detail. Please can anyone interpret these for me?
DHCP: QScan: Timed out Selecting state
DHCP: QScan: Purging entry
DHCP: deleting entry a54694 0.0.0.0 from list
Temp IP addr: 0.0.0.0 for peer on Interface: unknown
Temp sub net mask: 0.0.0.0
DHCP Lease server: 0.0.0.0, state: 8 Purging
DHCP transaction id: 0x239C929
Lease: 0 secs, Renewal: 0 secs, Rebind: 0 secs
No timer running
Retry count: 0 Client-ID:
DHCP command failed
DHCP client msg received, fip=10.153.64.1, fport=67
DHCP: Received a BOOTREP pkt Not for us..: xid: 0x4B44
DHCP: allocate request
DHCP get addr: existing ip lease str = 0x9e74bc
DHCP: zapping entry in DHC_PURGING state for outside
DHCP: new entry. add to queue
DHCP: new ip lease str = 0x9e765c
DHCP: SDiscover attempt # 1 for entry:
Temp IP addr: 0.0.0.0 for peer on Interface: outside
DHCP Lease server: 0.0.0.0, state: 1 Selecting
DHCP transaction id: 0x23ACDC5
Next timer fires after: 2 seconds
Retry count: 1 Client-ID: cisco-000d.bd3b.fb47-outside
DHCP: SDiscover: sending 273 byte length DHCP packet
DHCP: SDiscover 273 bytes
DHCP Broadcast to 255.255.255.255 from 0.0.0.0
DHCP: deleting entry 9e731c 0.0.0.0 from list
DHCP transaction id: 0x23A1057
No timer running
DHCP: SDiscover attempt # 2 for entry:
Retry count: 2 Client-ID: cisco-000d.bd3b.fb47-outside
DHCP: SDiscover attempt # 3 for entry:
Retry count: 3 Client-ID: cisco-000d.bd3b.fb47-outside
DHCP get addr: existing ip lease str = 0x9e765c
DHCP: new ip lease str = 0x9e731c
DHCP transaction id: 0x23B1B3E
DHCP: deleting entry 9e717c 0.0.0.0 from list
DHCP transaction id: 0x23A5F0C
No timer running
DHCP get addr: existing ip lease str = 0x9e731c
DHCP: new ip lease str = 0x9e717c
DHCP transaction id: 0x23B4907
DHCP: deleting entry 9e74bc 0.0.0.0 from list
DHCP transaction id: 0x23AA2F6
No timer running
DHCP get addr: existing ip lease str = 0x9e717c
DHCP: new ip lease str = 0x9e74bc
DHCP transaction id: 0x23B83BB
DHCP Broadcast to 255.255.255.255 from 0.0.0.0....
DHCP: new ip lease str = 0x9ea284
DHCP transaction id: 0x23BC87D
DHCP: deleting entry 9e765c 0.0.0.0 from list
No timer running
Max,
Try leaving the Surfboard switched off overnight and then getting an IP address from Blueyonder (after switching the Surfboard back on, of course!). I have set up a PIX running on the back of a Blueyonder cable connection in the past, so they do coexist.
Thanks a lot for your reply and clarifying this for me. I was beggining to worry about a compatibility issue.
I have actually tried that however I have swapped cables and done a write erase since then so I will give it another go.
Cheers
Max...
Chris (or anyone)
The 501 still isn't being assigned a DHCP address on the Outside when connected to the Motorola Surfboard. The retry is set to 4 and I get a row of dots and eventually "DHCP Failed".
I have performed a write erase and I can definitely confirm that Ethernet0's MAC address is registered with Blueyonder under Self Care.
I have tested Ethernet0 and it is fine. I have also tried various combinations of reboots can cables.
Any further comments/suggestions from anyone would be much appreciated.
Cheers
Max...
Gold
Max,
Can actually ping the DHCP server from a perimeter router and also, can you post your PIX and Primeter router config either here or to me at noc1@vodafone.net (please change real IP's and passwords). PS. You work for boxing orange don't you?
Thanks - Jay
Hi Jay
If I had a perimeter router that is one of the first things I would have tried :) Because I am plugging the PIX Outside into a Motorola Surfboard (cable modem) I am blind to whatever is beyond. In the debugs I am seing packets from address 10.153.64.1 which I assume is Blueyonder. Unfortunately I cannot ping out from the PIX because I cannot receive a DHCP assigned address.
PS: Yes? :)
Cheers
Max...
Gold
Max,
The bad news is that I can't reach that IP address (if it is the DHCP server of Blueyonder), here's the result:
NOC_AS0_Internet#ping 10.153.64.1
Sending 5, 100-byte ICMP Echos to 10.153.64.1, timeout is 2 seconds:
Get hold of Blueyonder (if you can) and verify the IP address of the DHCP server!!
Thanks - Jay
Hi Jay
Yep, obviously it is RFC1918 and not routable. I assume it can only be reached from Blueyonder's network.
Even if I have the IP address of the DHCP server there is probably nothing I can do with it. I have fired off an Email to Blueyonder Tech Support but I aren't confident.
Cheers anyway
Max...
182
