PIX506 and a Cable modem
I am having trouble with an application using a PIX506 and a cable modem.
Here is a copy of my config, very basic.
Any thoughts.
PIX Version 6.2(2)
nameif ethernet0 outside security0
nameif ethernet1 inside security100
enable password xxxxxxxxxxxxxxxxx encrypted
passwd xxxxxxxxxxxxxxxxxxx encrypted
hostname pixfirewall
fixup protocol ftp 21
fixup protocol http 80
fixup protocol h323 h225 1720
fixup protocol h323 ras 1718-1719
fixup protocol ils 389
fixup protocol rsh 514
fixup protocol rtsp 554
fixup protocol smtp 25
fixup protocol sqlnet 1521
fixup protocol sip 5060
fixup protocol skinny 2000
names
pager lines 24
logging on
interface ethernet0 10baset
interface ethernet1 10baset
mtu outside 1500
mtu inside 1500
ip address outside dhcp setroute
ip address inside 10.10.1.10 255.255.0.0
ip audit info action alarm
ip audit attack action alarm
pdm history enable
arp timeout 14400
nat (inside) 1 0.0.0.0 0.0.0.0 0 0
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 rpc 0:10:00 h323 0:05:00 si
p 0:30:00 sip_media 0:02:00
timeout uauth 0:05:00 absolute
aaa-server TACACS+ protocol tacacs+
aaa-server RADIUS protocol radius
aaa-server LOCAL protocol local
no snmp-server location
no snmp-server contact
snmp-server community public
no snmp-server enable traps
floodguard enable
no sysopt route dnat
telnet 10.10.0.0 255.255.0.0 inside
telnet timeout 5
ssh timeout 5
terminal width 80
Cryptochecksum:84e4ebe067ebbc6805cf74ea0046d614
I also cannot get into the 506 using explorer from the inside.
thanks
1 REPLY
Re: PIX506 and a Cable modem
add the following lines to your config and use HTTPS to browse to the pix (http is not supported, only https)
http server enable
http A.B.C.D 255.255.255.255 inside
A.B.C.D is the ip address of the host from which you are trying to reach the pix with the webbrowser. Make sure that DES or 3DES is enable, otherwise you will not be able to reach the pix.
If you're still having problems after adding these two lines, you could have a look at this page:
http://www.cisco.com/warp/customer/110/pdm_http404.shtml
For outside access, you also need a global statement in combination with the nat statement.
Add this line for outside access:
global (outside) 1 interface
Kind Regards,
Tom
73
