PIX506E Setting IP on Ethernet0.?
Hi All,
sorry, just label me an idiot, but, why isn't this working.? Cheers.
coolboarderguy...
pixfirewall(config)# ip address interface ethernet0 192.168.1.2 255.255.255.252
Usage: ip address <if_name> <ip_address> [<mask>]
ip address <if_name> dhcp [setroute] [retry <retry_cnt>]
ip address <if_name> pppoe [setroute]
ip address <if_name> <ip_address> <mask> pppoe [setroute]
ip local pool <poolname> <ip1>[-<ip2>]
ip verify reverse-path interface <if_name>
ip audit [name|signature|interface|attack|info] ...
show|clear ip audit count [global] [interface <interface>]
show ip address <if_name> [pppoe|dhcp [lease|server]]
  • Other Security Subjects
Silver
Re: PIX506E Setting IP on Ethernet0.?
The syntax is
ip address outside 192.168.1.2 255.255.255.252
Instead of using e0 or e1, use the name you applied to the interface, defaults to inside or outside. This is case specific and can be changed with the nameif command.
Andy
Hi All,
thanx, I'll pick up my dummy award on the way out. Cheers.
coolboarderguy...
Silver
Dont worry, least it fixed the problem
Andy
106
