Pix506e with PPPOE AND VPN
I have a Pix506e running 6.3 that is connected using PPOE to my DSL provider. Everything is working fine for internet traffic and for traffic coming back in to access FTP and mail servers.
Is it possible to configure a VPN tunnel using IPSec to terminate on the outside interface of the PIX? If so, is there a sample config that I could use as a template?
The outside interface is using the following command to pick up a IP address from the ISP.
ip address outside dhcp setroute
Thanks.
1 REPLY
Silver
Re: Pix506e with PPPOE AND VPN
Yes possible!
This link will provide you with all the details you are looking for.
http://www.cisco.com/en/US/partner/products/hw/vpndevc/ps2284/products_configuration_example09186a00801dd672.shtml
Nadeem
92
