Pix515 and ACL for RDP
Gents,
I have strange trouble. I added entry into inINS rules for out RDP access, but it doesn't work. Any advises or suggestions ?
PIX Version 7.0(5)
The added string is
access-list inINS extended permit tcp 10.30.65.0 255.255.255.0 any eq 3389
My config attached.
Thanks.
  • Other Security Subjects
Re: Pix515 and ACL for RDP
Hi .. I am assuming your are trying to access servers on your DMZ from devices on your inside right ..? you might want to try adding a nat (0) instruction ..i.e
access-list nonat extended permit tcp 10.30.65.0 255.255.255.0 any eq 3389
nat (inside) 0 access-list nonat
you might also need another one for the dmz interface i.e
access-list dmznonat extended permit ip any 10.30.65.0 255.255.255.0
nat (dmz) 0 access-list dmznonat outside
I hope it helps .. please rate it if it does
No, I try outgoing RDP from 10.30.65.0/24 network to outside.
I rebooted the PIX, all is ok and working.
Why it didn't work before reload ?
All rules are correct.
I tried clear translations, but that have not helped.
clear xlate
clear nat
Any comments ?
Thanks.
106
