04-01-2003 11:32 PM - edited 03-09-2019 02:44 AM
I need to open a session X between an inside interfaceand the dmz. I put a acl by opening the port xdmcp inside towards dmz but how to make for dmz towards inside and ports 6000 and 6063?
thanks
04-03-2003 03:41 AM
Inside will have access to DMZ if no ACL are in place, DMZ will have a path back to the inside interface as it has a TCP state open.
If you are using ACLs to control inside outbound traffic you will have to enable a return ACL on the DMZ interface.
04-03-2003 04:14 AM
I am using ACLs to control the traffic, I put this one
access-list inside-int permit udp host X.Y.Z.0 host A.B.C.D eq 177
but I can't define the return ACL
access-list dmz-int permit tcp host A.B.C.D host X.Y.Z.W eq ?????
04-03-2003 05:50 PM
the access-list only effect the income traffic to the pix
