PIX515 - not letting remote subnet out?
I have 3 remote offices connected via Fram connection. I can ping the ehternet interface on the HQ reouter from the remote locations, so I know I'm routing packets. The Ethenet interface can get out of the network though the PIX, though all of the other remote offices cannot.
It seems like I need to allow their subnet to have access to the outside???
Scott<-
Re: PIX515 - not letting remote subnet out?
You need to have routes for all these subnets for PIX to route packets back.
R/Yusuf
So I added the following:
route inside 10.2.0.0 255.255.0.0 10.1.0.1 1
route inside 10.3.0.0 255.255.0.0 10.1.0.1 1
route inside 10.4.0.0 255.255.0.0 10.1.0.1 1
route inside 10.5.0.0 255.255.0.0 10.1.0.1 1
and I can from the PIX ping the remote ethernet interface on the other routers. Though from the other routers I cannot ping the PIX's internal interface. I can on the Router that is in the same subnet as the PIX.
From the remote networks I can ping the ethernet interface on the router in the same subnet as the PIX, so I'm pretty sure the issues are on the PIX.
I'm stull pretty new at all of this. so I'm sure its something pretty simple.
Thanks for your help!
Scott<-
I've added routes for the other Subnets, though I'm not sure my NAT is letting them through.
Here is what I have so far:
access-list inside_outbound_nat0_acl permit ip any 10.0.0.0 255.0.0.0
global (outside) 1 192.168.126.21-192.168.126.59 netmask 255.255.255.0
global (outside) 1 192.168.126.20 netmask 255.255.255.0
nat (inside) 0 access-list inside_outbound_nat0_acl
nat (inside) 1 10.0.0.0 255.0.0.0 0 0
route outside 0.0.0.0 0.0.0.0 192.168.126.2 1
! Remote Office 1 Subnet
! Remote Office 2 Subnet
! Remote Office 3Subnet
! Remote Office 4Subnet
!Serial Port Subnets
route inside 10.254.0.0 255.255.0.0 10.1.0.1 1
Any Suggestions would be appreciated.
Scott<-
96
