PIX515, UDP connection deleted
Sending UDP pings with source port 501 from host 10.30.19.1, source port 501 (inside) to an outside host (e.g. 10.30.32.6, dest. port 500) are blocked from by the PIX. I just see the following logging entries:
302015: Built outbound UDP connection 44476 for out_RTRC1:10.30.32.6/500 (10.30.32.6/500) to in_SGRC1:10.30.19.1/501 (10.30.19.1/501)
302015: Built outbound UDP connection 44483 for out_RTRC1:10.30.32.10/500 (10.30.32.10/500)
302016: Teardown UDP connection 44374 for out_RTRC1:10.30.32.26/500
to in_SGRC1:10.30.19.1/500 duration 0:33:58 bytes 28996
302015: Built inbound UDP connection 44457 for out_RTRC1:10.30.32.26/500 (10.30.32.26/500)
to in_SGRC1:10.30.19.1/500 (10.30.19.1/500)
The traffic is not blocked by an access-rule (think so), but I can't see any reason for this behaviour. Also a debugging on the router connected to the outside interface of the PIX didn't show this udp packets coming in.
Normally upd port 500 is ued for IKE protocol. Could it be that the PIX has problems when udp pings are sent on the same dest. port?
Please find bellow the config of my PIX, any help is very welcome.
PIX Version 6.3(3)
interface ethernet0 100full
interface ethernet1 100full shutdown
interface ethernet2 100full
interface ethernet3 100full
interface ethernet4 auto shutdown
interface ethernet5 auto shutdown
nameif ethernet0 in_SGRC1 security99
nameif ethernet1 in_SGRC2 security99
nameif ethernet2 out_RTRC1 security20
nameif ethernet3 out_RTRC2 security20
nameif ethernet4 intf4 security8
nameif ethernet5 intf5 security10
enable password xxx encrypted
passwd xxx encrypted
hostname FWLC1
clock timezone GMT 1
clock summer-time GMT recurring
fixup protocol dns maximum-length 512
fixup protocol ftp 21
fixup protocol h323 h225 1720
fixup protocol h323 ras 1718-1719
fixup protocol http 80
fixup protocol ils 389
fixup protocol rsh 514
fixup protocol rtsp 554
fixup protocol sip 5060
fixup protocol sip udp 5060
fixup protocol skinny 2000
fixup protocol smtp 25
fixup protocol sqlnet 1521
fixup protocol tftp 69
names
access-list 100 permit esp 10.30.32.0 255.255.224.0 10.30.19.0 255.255.255.248
access-list 100 permit esp 10.30.64.0 255.255.192.0 10.30.19.0 255.255.255.248
access-list 100 permit udp 10.30.32.0 255.255.224.0 10.30.19.0 255.255.255.248 eq isakmp
access-list 100 permit udp 10.30.64.0 255.255.192.0 10.30.19.0 255.255.255.248 eq isakmp
access-list 100 permit icmp host 10.30.22.10 host 10.30.7.50
access-list 100 permit icmp host 10.30.22.10 host 10.30.7.52
access-list 100 permit udp host 10.30.22.10 host 10.30.7.70 eq snmptrap
access-list 100 permit udp host 10.30.22.10 host 10.30.7.50 eq syslog
access-list 100 permit udp host 10.30.22.10 host 10.30.7.52 eq syslog
access-list 100 permit udp host 10.30.22.10 host 10.30.7.70 eq syslog
access-list 100 permit tcp host 10.30.22.10 host 10.30.1.210 eq 123
access-list 100 permit udp host 10.30.22.10 host 10.30.1.210 eq ntp
access-list 100 deny ip any any log
access-list all-ip-packet permit ip any any
access-list 110 permit esp 10.30.128.0 255.255.192.0 10.30.19.0 255.255.255.248
access-list 110 permit esp 10.30.192.0 255.255.240.0 10.30.19.0 255.255.255.248
access-list 110 permit udp 10.30.128.0 255.255.192.0 10.30.19.0 255.255.255.248 eq isakmp
access-list 110 permit udp 10.30.192.0 255.255.240.0 10.30.19.0 255.255.255.248 eq isakmp
access-list 110 permit icmp host 10.30.23.10 host 10.30.7.50
access-list 110 permit icmp host 10.30.23.10 host 10.30.7.52
access-list 110 permit udp host 10.30.23.10 host 10.30.7.70 eq snmptrap
access-list 110 permit udp host 10.30.23.10 host 10.30.7.50 eq syslog
access-list 110 permit udp host 10.30.23.10 host 10.30.7.52 eq syslog
access-list 110 permit udp host 10.30.23.10 host 10.30.7.70 eq syslog
access-list 110 permit tcp host 10.30.23.10 host 10.30.1.210 eq 123
access-list 110 permit udp host 10.30.23.10 host 10.30.1.210 eq ntp
access-list 110 deny ip any any log
access-list 120 permit esp 10.30.19.0 255.255.255.248 10.30.32.0 255.255.224.0
access-list 120 permit esp 10.30.19.0 255.255.255.248 10.30.64.0 255.255.192.0
access-list 120 permit esp 10.30.19.0 255.255.255.248 10.30.128.0 255.255.192.0
access-list 120 permit esp 10.30.19.0 255.255.255.248 10.30.192.0 255.255.240.0
access-list 120 permit udp 10.30.19.0 255.255.255.248 10.30.32.0 255.255.224.0 eq isakmp
access-list 120 permit udp 10.30.19.0 255.255.255.248 10.30.64.0 255.255.192.0 eq isakmp
access-list 120 permit udp 10.30.19.0 255.255.255.248 10.30.128.0 255.255.192.0 eq isakmp
access-list 120 permit udp 10.30.19.0 255.255.255.248 10.30.192.0 255.255.240.0 eq isakmp
access-list 120 permit udp host 10.30.19.1 10.30.32.0 255.255.224.0 eq isakmp
access-list 120 permit udp host 10.30.19.1 10.30.64.0 255.255.192.0 eq isakmp
access-list 120 permit udp host 10.30.19.1 10.30.128.0 255.255.192.0 eq isakmp
access-list 120 permit udp host 10.30.19.1 10.30.192.0 255.255.240.0 eq isakmp
access-list 120 permit icmp host 10.30.7.50 host 10.30.20.10
access-list 120 permit icmp host 10.30.7.52 host 10.30.20.10
access-list 120 permit icmp host 10.30.7.50 host 10.30.22.10
access-list 120 permit icmp host 10.30.7.52 host 10.30.22.10
access-list 120 permit icmp host 10.30.7.50 host 10.30.23.10
access-list 120 permit icmp host 10.30.7.52 host 10.30.23.10
access-list 120 permit udp host 10.30.7.50 host 10.30.22.10 eq snmp
access-list 120 permit udp host 10.30.7.52 host 10.30.22.10 eq snmp
access-list 120 permit udp host 10.30.7.70 host 10.30.22.10 eq snmp
access-list 120 permit udp host 10.30.7.50 host 10.30.23.10 eq snmp
access-list 120 permit udp host 10.30.7.52 host 10.30.23.10 eq snmp
access-list 120 permit udp host 10.30.7.70 host 10.30.23.10 eq snmp
access-list 120 permit tcp host 10.30.7.60 host 10.30.22.10 eq cmd
access-list 120 permit tcp host 10.30.7.62 host 10.30.22.10 eq cmd
access-list 120 permit tcp host 10.30.7.70 host 10.30.22.10 eq cmd
access-list 120 permit tcp host 10.30.7.60 host 10.30.23.10 eq cmd
access-list 120 permit tcp host 10.30.7.62 host 10.30.23.10 eq cmd
access-list 120 permit tcp host 10.30.7.70 host 10.30.23.10 eq cmd
access-list 120 permit udp host 10.30.1.210 host 10.30.22.10 eq ntp
access-list 120 permit udp host 10.30.1.210 host 10.30.23.10 eq ntp
access-list 120 deny ip any any log
pager lines 24
logging on
logging timestamp
logging buffered informational
logging trap critical
logging host in_SGRC2 10.30.7.70
mtu in_SGRC1 1500
mtu in_SGRC2 1500
mtu out_RTRC1 1500
mtu out_RTRC2 1500
mtu intf4 1500
mtu intf5 1500
ip address in_SGRC1 10.30.20.10 255.255.255.0
ip address in_SGRC2 10.30.21.10 255.255.255.0
ip address out_RTRC1 10.30.22.1 255.255.255.0
ip address out_RTRC2 10.30.23.1 255.255.255.0
no ip address intf4
no ip address intf5
ip audit info action alarm
ip audit attack action alarm
failover
failover timeout 0:00:00
failover poll 15
failover ip address in_SGRC1 10.30.20.11
failover ip address in_SGRC2 10.30.21.11
failover ip address out_RTRC1 10.30.22.2
failover ip address out_RTRC2 10.30.23.2
no failover ip address intf4
no failover ip address intf5
pdm history enable
arp timeout 14400
nat (in_SGRC1) 0 access-list all-ip-packet
nat (in_SGRC2) 0 access-list all-ip-packet
static (in_SGRC1,out_RTRC1) 10.30.7.60 10.30.7.60 netmask 255.255.255.255 0 0
static (in_SGRC1,out_RTRC1) 10.30.19.1 10.30.19.1 netmask 255.255.255.255 0 0
static (in_SGRC1,out_RTRC2) 10.30.19.1 10.30.19.1 netmask 255.255.255.255 0 0
static (in_SGRC1,out_RTRC1) 10.30.19.2 10.30.19.2 netmask 255.255.255.255 0 0
static (in_SGRC1,out_RTRC2) 10.30.19.2 10.30.19.2 netmask 255.255.255.255 0 0
static (in_SGRC1,out_RTRC1) 10.30.19.3 10.30.19.3 netmask 255.255.255.255 0 0
static (in_SGRC1,out_RTRC2) 10.30.19.3 10.30.19.3 netmask 255.255.255.255 0 0
static (in_SGRC1,out_RTRC1) 10.30.19.4 10.30.19.4 netmask 255.255.255.255 0 0
static (in_SGRC1,out_RTRC2) 10.30.19.4 10.30.19.4 netmask 255.255.255.255 0 0
static (in_SGRC2,out_RTRC1) 10.30.19.1 10.30.19.1 netmask 255.255.255.255 0 0
static (in_SGRC2,out_RTRC2) 10.30.19.1 10.30.19.1 netmask 255.255.255.255 0 0
static (in_SGRC2,out_RTRC1) 10.30.19.2 10.30.19.2 netmask 255.255.255.255 0 0
static (in_SGRC2,out_RTRC2) 10.30.19.2 10.30.19.2 netmask 255.255.255.255 0 0
static (in_SGRC2,out_RTRC1) 10.30.19.3 10.30.19.3 netmask 255.255.255.255 0 0
static (in_SGRC2,out_RTRC2) 10.30.19.3 10.30.19.3 netmask 255.255.255.255 0 0
static (in_SGRC2,out_RTRC1) 10.30.19.4 10.30.19.4 netmask 255.255.255.255 0 0
static (in_SGRC2,out_RTRC2) 10.30.19.4 10.30.19.4 netmask 255.255.255.255 0 0
access-group 120 in interface in_SGRC1
access-group 120 in interface in_SGRC2
access-group 100 in interface out_RTRC1
access-group 110 in interface out_RTRC2
route in_SGRC1 0.0.0.0 0.0.0.0 10.30.20.2 1
route out_RTRC1 10.30.32.0 255.255.224.0 10.30.22.10 1
route out_RTRC1 10.30.64.0 255.255.224.0 10.30.22.10 1
route out_RTRC2 10.30.128.0 255.255.224.0 10.30.23.10 1
route out_RTRC2 10.30.160.0 255.255.224.0 10.30.23.10 1
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 rpc 0:10:00 h225 1:00:00
timeout h323 0:05:00 mgcp 0:05:00 sip 0:30:00 sip_media 0:02:00
timeout uauth 0:00:00 absolute
timeout xlate 0:01:00
aaa-server TACACS+ protocol tacacs+
aaa-server RADIUS protocol radius
aaa-server LOCAL protocol local
ntp server 10.30.1.210 source in_SGRC1
snmp-server host in_SGRC1 10.10.7.70
snmp-server host in_SGRC2 10.10.7.70
snmp-server host in_SGRC1 10.20.7.70
snmp-server host in_SGRC2 10.20.7.70
no snmp-server location
no snmp-server contact
snmp-server community
snmp-server enable traps
floodguard enable
telnet 10.30.0.0 255.255.0.0 in_SGRC1
telnet timeout 5
ssh timeout 5
console timeout 0
terminal width 80
1 REPLY
Re: PIX515, UDP connection deleted
Starting from your basic config, I can see int e1, e4 and e5 are shutdown so I wont comment about those. but why have u chosen to give your int e2 and e3 the same security level of 20?? Defeats the whole principle behind ASA and to my knowlege not a supported config.
100
